Results 1 to 13 of 13
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    Air box....rocks? help
    No really there is tons of little rocks and sand type rocks in my air box. See pics. What do I do about this?
    http://farm4.static.flickr.com/3314/...b81e96.jpg?v=0
    http://farm4.static.flickr.com/3499/...d1f229.jpg?v=0
    Also, do I need this check valve because the end just snapped when I went to touch it?
    http://farm4.static.flickr.com/3098/...93d3df.jpg?v=0
    Veteran Member Three Rings davyboi's Avatar
    Jun 03 2008
    So.CAL
    Re: Air box....rocks? help
    yes...change the check valve
    May 11 2008
    Columbus, OH
    Has anyone else had all this stuff in their air box? Does it matter? What is that particular check valve for?
    http://i314.photobucket.com/albums/l...or_02_1_8t.jpg
    Why can't I just get rid of the line that is attached to #3?
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I'd remove that box and wash it out. Yes you need that check valve. You can probably super glue together until you get a new one to avoid a CEL. It just looks as if it's never been cleaned out.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    May 11 2008
    Columbus, OH
    What about for the people who have removed all their check valves and lines from their system. Wouldn't I be able to do that to a portion of the system and be ok?
    Established Member Two Rings afozzie40's Avatar
    Oct 21 2008
    B6 A4 1.8T
    Boulder, Colorado
    shop vac and put your snow screen back in
    03 B6 MT Sport suspension 15% Tint Custom Magnaflow exhaust K&N Stock Air Box Mod ECS Snub
    May 11 2008
    Columbus, OH
    the snow screen is all chewed up and busted...need a new one I guess
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    you need that screen, and the check valve. go buy new parts and install.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    F the screen. Just keep it clean and as long as your filter is good, you are good.
    Senior Member Two Rings Wanted's Avatar
    May 17 2007
    A4 Quattro, vert Z, Jeep XJ
    Louisville, KY
    That's the dirtiest airbox I think I've ever seen and I'm an offroader with a big ole jeep in my stable. I don't think I've ever seen that much hard/large particle debri in a box before. That's amazing!
    Like they said I'd go ahead and vacuum the whole thing spotless and then super glue the valve til you can replace.
    1 more red A4, 3.0, 6spd Quattro...
    Now with a "free" Imola B5 S4 6spd
    Jun 09 2007
    Dallas
    yeah, mine was full of leaves and debris also. and it pretty much like exactly that how yours was.
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    mine had sand in it but never any big rocks...clean it out and k&n filter
    211,000 miles
    ||Borla||forge dv||35%||awe||k&n||autobahn hoses||awe smic||ssac||walbro 255||
    Veteran Member Four Rings QTC's Avatar
    Sep 16 2006
    2004 B6 A4 1.8t 6MT; 2013 F30 320i 6MT; 99.5 Pathfinder 4x4; Mk7 Golf TDI
    Wynnewood, PA
    Do they use sand when it snows on the roads where you live? That might be the culprit
    Dahlback | AWE | Milltek | Vogtland | H-Sport | Oettinger | Thule | OEM+
