Results 1 to 18 of 18
    Sep 16 2008
    Tools
    Rochester, NY
    MAF on its way out or O2?
    So I have been seeing code 17536 for a while now and its time to make the CEL go away.
    Background:
    1997 Audi A4 18tqm
    ko4-015
    Unitronic k04 file
    VR6 maf housing
    USRT 380cc injectors
    3 bar FPR
    ATP 3" TP
    Borla 2.5 stainless exhaust
    Forge TIP
    at WOT im seeing 150-160 g/s from my maf.
    - This is normal? 80% of hp? meaning my k04 is making ~200 hp @ 22psi
    at idle I see 2.10 - 2.50 g/s from the MAF
    -This is normal? I was told as long as its above 2.00 its ok?
    at 032 block i see 10.5% and 25% respectively.
    - This is bad. 25% is maxed. Front O2 sensor possibly?
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: MAF on its way out or O2?
    Have you logged the 02 sensor readings at wot? If the 02 is going bad the readings should look very lean at WOT.
    Where are the specs for the Unitronic K04 file? I only see their stage 1-1+ and the BT files on their web site.
    Sep 16 2008
    Tools
    Rochester, NY
    Before After
    0.415 0.685 2000 RPM
    0.825 0.835
    0 0.01
    0.03 0.045
    0.835 0.855
    0.835 0.855
    0.86 0.875
    0.83 0.855
    0.81 0.835
    0.775 0.8
    0.78 0.82 6700 RPM
    Looks alright right?
    Jul 07 2004
    socal
    A little lean, .85 is 12.5:1 on a narrow band.
    Sep 16 2008
    Tools
    Rochester, NY
    So which would you look at first? O2 or MAF?
    Jul 07 2004
    socal
    The maf readings look normal for a 3" maf housing. A maf that is going bad will also cause the ecu to run more adv timing, so you might want to check block 022 to see how much timing pull you have. Load readings at the maf would also be much lower then they normally would be.
    Sep 16 2008
    Tools
    Rochester, NY
    0 0 0 0
    0 0 0 0
    0 0 0 0
    0 0 0 0
    0 0 0 0
    2.2 0 2.2 2.2
    1.5 0 2.2 1.5
    0.7 0 1.5 0.7
    0 0 0.7 0
    0 0 0 0
    3 0 0 3
    thats the timimng retard value in block 020
    Jul 07 2004
    socal
    Then its most likey the 02 sensor thats going bad, causing the ecu to keep adding more fuel to get the 02 readings back up.
    Have you checked for any exhaust leaks before the 02 sensor? That can also cause the 02 sensor to read leaner and make the ecu add more fuel.
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    mike, I'm going to have to disagree with you, kinda. while the 02 sensor can very likely be faulty, as well as an upstream exhaust leak (seeing as how the turbo has been replaced); I had the exact same fault (bank1 fuel trim multiplicative - system too lean). this was also causing me to get soft limp mode and only boost to 5psi! I would run basic setting 107 (short term fuel trim) and within seconds, my fuel trim would jump up to 25%. my readings for 32 were -1.0 and 25%. I unplugged my maf and it still happened, and all my maf values were fine (03, 115, 211 @ idle). I tried many things including fuel pressure regulator, injector clean, fuel filter, boost/vacuum leaks (even though this would be lean at idle and rich under boost). but then I decided to check 211 under load. there was an up to 70g/s diference between specified and actual values. I swapped in a maf on a known good b6, and the difference went to less than 20g/s. replaced the maf and hadnt had a problem since.
    I would suggest logging block 211 while WOT in 2nd/3rd gear. good luck and looking forward to updates. peace.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Jul 07 2004
    socal
    Yes, but your 032 readings showed that the ecu was ok at idle(pulling 1%) and at part throttle needed to add max fuel. His is adding 10% at idle and add max at part throttle. His maf readings are where they should be at WOT for a stock maf in a 3" housing. Those things there are the reason I think its the 02 sensor or a exhaust leak causing the 02 to read lean.
    Apr 06 2008
    Brandon, FL
    ahh. i didnt notice his idle reading was 10%. thanks for the clarification mike. i would still like to see his values for 211 though, just to be sure.
    Current whip:
    RIP:
    Sep 16 2008
    Tools
    Rochester, NY
    Ill grab the 211 readings in the morning.
    Im positive I have no upstream exhaust leaks as Im anal about replacing hardware and gaskets EVERY time the turbo is removed.
    Im ordering an o2 sensor overnight tomorrow. if it doesnt do the trick ill order a maf.
    Thanks guys!
    Sep 16 2008
    Tools
    Rochester, NY
    So I ordered a new 02 sensor and put it in, cleared codes and still it jumps up to 25% trim.
    Whats next?
    Apr 06 2008
    Brandon, FL
    log 211 at wot in 3rd gear. if the specified and actual g/s vary by more than 20, replace your maf.
    Current whip:
    RIP:
    Sep 16 2008
    Tools
    Rochester, NY
    I have no 211 block.
    I am on early ecu, mapless. (97 AEB DBC)
    Apr 06 2008
    Brandon, FL
    what are you using to log the blocks. is it base version of vag-com? i believe you can still see 211 on the early models as the block reads load %, g/s specified, and g/s actual, but maybe not available due to specified (speed density using map input). see if you can borrow someones maf, even if not new, it should improve. i put a b6 one in to test mine and the multiplicative lean fault wouldnt come back, and fuel trims were ok. i had that exact fault and full lean off idle and a maf fixed it.
    Current whip:
    RIP:
    Sep 16 2008
    Tools
    Rochester, NY
    I put a bran new MAF in it and im still seeing the same results
    Veteran Member Three Rings kevin12's Avatar
    Jun 20 2007
    01.5 A4 1.8TQM
    South Jersey
    I've been having the same code for atleast 6 months, come and go sometimes, but it has been on all the time for awhile now. Finally got around to replacing the front o2 sensor and still got the code coming back.
    But I just recently logged block 002 and the maf on the stock tune is only around 113 g/s under WOT in second where it should be around 136 for my 01.
    So I figure its the maf but still not 100% sure. Already order a new one and I'm waiting for it to get here soooo we shall see if it fixes my problems like it fixed Kev's. My trims were also around 1.1% and 25%...
    Current:
    17 Ibis White A3 2.0TQ S-Line
    01.5 Santorin Blue A4 1.8TQ 5-Speed
    Uni 1+, XS Power Exhaust, ST Coilovers, Forge DV
    99.5 Laser Red A4 2.8Q Tip Totaled RIP
    01.5 Casa White A4 1.8TQ Tip Current Parts Car
    08 Ibis White A4 2.0TQ Tip S-Line
