View Poll Results: Which would you do?
Voters
49. You may not vote on this poll
  • AWE FMIC then AWE quad-tip exhaust
    15 30.61%
  • AWE quad-tip exhaust then AWE FMIC
    27 55.10%
  • AWE FMIC then custom exhaust (Automatic here)
    7 14.29%
Results 1 to 19 of 19
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    Lightbulb AWE qaud-tip exhaust or AWE FMIC?
    What would you do first? I was planning on going with the exhaust but they've been taking so long to make them that I'm starting to think that their FMIC is a better mod, especially after reading that magazine article on it. It is cold out here in Jersey so the car is running great but I remember how heatsoaked it got at Waterfest when it was about a hundred degrees out. I am automatic so I might just have a muffler shop custom build me an exhaust with magnaflows later on. All ideas appreciated.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Veteran Member Three Rings kharsnett's Avatar
    Oct 24 2006
    Indianapolis IN
    Re: AWE qaud-tip exhaust or AWE FMIC?
    man that is a hard decision. i say go with the fmic first then the awe exhaust
    B7 A4 Non sline Sline Edition, High flow fog light holes, Titanium license plate screws, Cross drilled lug bolts, greasy axle, Coolant relief valve on cylinder head, Pressure relieving boost hoses, Cylinder Head Exchange program, Custom cam grind, used fuel pump follower, variable geometry front Control Arms, Automatically shifted manual transmission, 87 octane APR tune, detuned 83 Octane APR tune, Custom high flow Flex section, Custom built spark plugs, Ebay sponsored!
    Veteran Member Four Rings eastwick897's Avatar
    Jun 26 2008
    New Jersey
    hey red definitely do the FM you won't regret it. It's better for the car then the exhaust anyway
    B7 A4.... 394awhp
    Veteran Member Four Rings ggg20t's Avatar
    Sep 18 2008
    Pittsburgh, PA
    ^^ i dont know about the FMIC being "better" - that is a pretty generic way to put it. I currently have the Quad tip exhaust and love it. Yes, they do take a long time and i became frustrated but the day i drove out of the garage with it on, it was well worth the wait. Now, correct me if i am mistaken, but i believe the AWE FMIC requires you to take off that steel beam that sits behind the bumper (safety feature)--i don't think that is worth it. I have thought about this a lot, and i think the best way to go for an FMIC if you are taking into consideration warranty/saftey (which taking that steel piece off will void warranty), I would most likely get an FMIC that fits under that steel beam such as the Ghost Squad Garage one does (which is cheaper than the AWE one and gets great reviews).
    As for the FMIC being "better" for your car -- if he means it cools the turbo better allowing for longer turbo life and more power, he is correct -- but at the same time, if your turbo is able to produce more power at a lower temperature, that means that there is going to be more back pressure produced from this increase in power.....In other words, your car will potentially be bogged down by the stock exhaust not being able to handle more back pressure....
    I would do a short ram air intake/exhaust combo first, and then an fmic.
    Jan 01 2008
    Long Island NY
    there is a member here selling an awe quad exhaust for cheap buy that.
    Sep 18 2008
    Pittsburgh, PA
    ^^ hell yea. do that. AWE FMIC is so expensive
    Veteran Member Four Rings EMAXX's Avatar
    Jul 12 2008
    Quote Originally Posted by ggg20t View Post
    You don't have to take off the crash bar. You take it off for installation then it mounts right back on.
    2015 Audi S4 Prem+ Sepang Blue/Magma, 6MT, Eurocode Alu Kreuz, Eurocode Transmission Brace, Eurocode Sway Bars and Endlinks, RocEuro Intake, AWE Touring Exhaust
    Veteran Member Three Rings 04Ultrasprt's Avatar
    Jan 13 2008
    North NJ
    I have both, if youre running stock turbo go with exhaust and a test pipe first. You may not notice a major power boost with either, but the exhaust will give your car a mean sound and a better look. I also love the fmic, but I'm not a big fan of the looks. I painted my pipes black and Im putting grills in on each side so that you cant see it. If you have any questions about either, pm me
    Previous rides:
    Lotus Elise - B6 S4 Cab - E90 335i - E46 ///M3 - B6 PES Stage 2 S4
    B6 Nogaro S4 - B5 S4 Stage II - B7 A4 2.0T K04 - B6 A4 1.8T USP
    USP CLUB MEMBER #95
    Sep 18 2008
    Pittsburgh, PA
    emaxx - it does?! i could have sworn i read a thread before that said it had to come off because of how big it is? my bad
    Jul 12 2008
    Yeah. There were tons of people complaining to AWE that the front crossbar comes out, reducing the safety of the car. AWE replied by stating that the crossbar comes out for installation, but bolts in on top of the FMIC.
    Mar 19 2008
    thanks for the info guys. I already have an intake and will NOT do a test pipe. maybe will get a labree high flow cat in the future but first i wanna hear how the exhaust sounds without additional mods. I ordered the exhaust on christmas special for 919 so i dont need to buy the one in the classifieds. im just getting bored with waiting and i get a chill down my spine every time i hear a turbo car with one of those tin can mufflers thinking that my car might end up sounding like that.
    2019 S5 BO.SS
    2009 R8 6 Volt :)
    Senior Member Three Rings BriAnders's Avatar
    Nov 04 2008
    Charlotte, NC
    those same people that think the crash bar is permanently removed for the AWE FMIC clearly didn't do their homework.
    Excuse me sir, but you left your muffler at the light back there.
    Veteran Member Four Rings quattrosaint's Avatar
    Sep 24 2007
    Dallas
    and so worth every penny! If you track your car AWE FMIC is a must! If you dont then I would say go with the exhaust.
    2007 A4 Quattro 2.0T Tip
    Go Fast:Custom GIAC Tune & APR HPFP & AWE FMIC & AWE Exhaust & Labree DP & K&N Filter & Forge DV & Eurojet PCV
    Stop: ECS Stg 4 Porsche BBK
    Twisties: H&R Springs & RS4 Sway & Ti Rims
    Stunt: S4 Grill & S4 Rear & Cupra R Spoiler & TTS Wheel & 8MM Spacers & CF Trunk
    Now................Mostly parted out. Thanks everyone who participated
    Jun 26 2008
    New Jersey
    Your steel beam stays in tact... The FM fits right behind it... Research dude!
    B7 A4.... 394awhp
    Mar 19 2008
    ^hey you ever check on your cam follower since having put your hpfp in? im seeing some awful pictures on vortex that scares me about getting one, especially since im an 06.
    2019 S5 BO.SS
    2009 R8 6 Volt :)
    Sep 24 2007
    Dallas
    Quote Originally Posted by RedS-line View Post
    still looks fine, im going to check it again soon when I decide if I want to go BT
    Veteran Member Four Rings ray-ray's Avatar
    Jul 08 2004
    Moreno Valley, CA
    get the exhaust first. If you are on a stock turbo and you don't plan on going to a BT anytime soon, then the FMIC can wait.
    Old Car: 2003 Audi A4 1.8T Dolphin Grey with AWE GT28R Turbo Kit
    New Car: 2008 Audi A4 2.0T Quattro Ibis White, GIAC X-Flash from Torque Factory
    Veteran Member Three Rings audidrver's Avatar
    Mar 31 2007
    CA
    def intercooler first
    ooooO..................Ooooo
    ...............oooo
    .........o.............o
    Sep 18 2008
    Pittsburgh, PA
    Eastwick -
    haha I know you aren't bashing me, but if there is one thing i have learned from this forum, it is that I definitely have to do my research before i make any comments so i don't get nailed!! My bad on the Crash Bar!!
    BTW red... I called up a friend of mine tonight who works as the head mechanic at a Porsche/Ferrari/Spyker dealer in Pittsburgh (i trust every word he says) - He told me the same thing he told me when i first started modding my car -- Exhaust + Intake is the perfect way to go at first. FMIC is something for the track.
    Also, your car will not sound like a fart can SI civic no matter what you put on it -- i do not know why .. probably bc German cars > Japanese Cars haha. But thats just my technical input on the situation
