Results 1 to 12 of 12
    Aug 10 2008
    UK
    HELP! Accident with headlamp plug
    I've tried to remove my headlamps - ones out withput a problem, but the other plug didn't disconnect, instead it lulled all the wires through from inside the housing.
    So instead of the plug disconnecting like this:-
    It looks like this:-
    I've tried seperating the two but can't seem to do it now. Does anyone know how to do it?
    Thanks in advanance.
    Jun 01 2008
    Apopka, FL
    Re: HELP! Accident with headlamp plug
    I really wish they would have used the metal clip connections everywhere instead of these crappy plastic release ones that get stuck all the time. What you need to do is insert a small screw-driver into the opposite side of the plug that you would normaly press down to release and pop the clip up. It will come right off with little force. It looks like you already tried to seperate it but you need to have that clip released before it will budge.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Then just epoxy the connector back into the light.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Aug 10 2008
    UK
    Sorry to sound stupid, but I don't know what you mean. I can't seem to dislodge it at all. Can you talk me through it a little more?
    Mar 21 2006
    Lakeland, FL.
    See the circled area, that is the clip/lock that holds the connectors together. You need to put a small screwdriver in it and press the screwdriver toward the connector and then pull on the connecters.
    I'm back bitches!
    Aug 10 2008
    UK
    That's fantastic thanks. I've followed your instructions and it's worked a treat . Was very tight though and didn't come out that easily, but it's out!
    Thanks again
    Mar 21 2006
    Lakeland, FL.
    They suck until you get the hang for them.
    I'm back bitches!
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    i destroyed half of those clips. they won't be coming off even unclipped.
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Veteran Member Three Rings Scrwedtxboy31's Avatar
    Oct 19 2008
    2004 A4 1.8TQM (6sp)
    VA
    lmao
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    yup, best way to remove them is to push and hold the plug in the closed direction, then insert screwdriver into the release and twist it. just pull up on the plug and it'll come right off.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Aug 10 2008
    UK
    Cheers guys - worked a treat. Plastic plug has a few scars now though
    Aug 26 2005
    Damaged harness connectors should be replaced with new.
