Results 1 to 10 of 10
    Established Member Two Rings b5hobsons4's Avatar
    Aug 22 2008
    2001 s4
    Southern Indiana
    Finally got around to putting up some pics
    I cracked my RS4 reps, so I sandblasted the stockers, sanded em, primed em, and painted em. They're growing on me.
    Veteran Member Three Rings belittle's Avatar
    Oct 01 2008
    Vail, AZ
    Re: Finally got around to putting up some pics
    I can't tell, bronze or black? Either looks awesome. I would have flat blacked them myself :)
    Aug 22 2008
    2001 s4
    Southern Indiana
    Quote Originally Posted by belittle View Post
    They're actualy Duplicolor Graphite. I think it was just the way the sun was hitting them that day.
    I had to take advantage of the 60 degree weather after chirstmas.
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    They look good! Did you clearcoat?
    What happened with the RS4 reps? Curbage/bump?
    Brilliant Black 2001 S4 - 6MT <3
    Account Terminated Four Rings
    Nov 30 2006
    01.5 pearl white S4 6speed
    annapolis, maryland
    Looks good man, clean whip
    Senior Member Three Rings jblinga's Avatar
    Jul 24 2008
    '01.5 S4, '96 Maxima
    Mor_onville U.S.A.
    They look good, probably the direction I'll go with my stockers.
    Ditch that front plate and get a new filler!
    '01.5 S4 6MT 2+
    '96 Maxima (DD)
    Senior Member Two Rings curlyfrieS4's Avatar
    Nov 19 2008
    S4 Twiny Terbs
    San Diego
    How much did it cost to get them sand blasted? and where did you get it done?
    Sold: 2000 S4 Stage II: 17' BBS RGRs. GIAC X. JHM FMIC. Piggie pipes. 710n's. RS4 clutch & flywheel. BORLA Cat Back. UUC Short Shifter. Stasis Coilovers. Need Brembo brake kit!!!!!!!
    Current: 2001 Audi S4. Stock :)
    Aug 22 2008
    2001 s4
    Southern Indiana
    Quote Originally Posted by JackalS4 View Post
    No, I decided against the clear coat, because I wasn't quite sure how it would hold up against chips, and how hard it would be to patch it with a clear on there.
    You can see on the right front wheel there are 3 spots on the spokes where it chipped. I was putting the wheel on and turned away to raise it for just one second and I saw it falling over on the face as I turned back. But so far, that has been the only chips on them. I've had em a little bit over a month now.
    As for the reps, I was driving to class and heard it up front. I parked it as soon as I could. Luckily, I'm only 1/4 to campus. Me and a buddy from class went to check it out after class. When we got it off, we noticed a huge dent in the inside lip. I can only remember hitting one bump hard, but that was back in July. There was a crack going across the width rim. Lesson learned: Don't buy rims for OE Production from Sarasota, FL off of Ebay.
    Aug 22 2008
    2001 s4
    Southern Indiana
    Quote Originally Posted by curlyfrieS4 View Post
    I blasted em myself at my dad's work. Sanded em smooth. Used duplicor filler primer, then i think 3 or 4 coats of Duplicolor graphite wheel paint. It took us about one night to do. I had maybe $45 in paint and primer. Sure beat spending $800 on another set of rims.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    cleanliness is next to Godliness playa
