Results 1 to 6 of 6
    Jan 24 2009
    2003 A4 Avant
    Averill Park, NY
    power steering problem
    i'm a relatively recent owner of a 2003 A4 Avant, just picked it up in November.
    About 2 weeks ago it started spewing the power steering fluid out past the cap on the reservoir. my mechanic doesn't know what to make of it, the local audi dealership doesn't either. the entire system was purged of fluid and refilled per audi instructions, it was ok for a week but now the fluid is gone again.
    any suggestions?
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: power steering problem
    Sounds like you may have a one way or check valve failing. But where is the question.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Senior Member Two Rings Wanted's Avatar
    May 17 2007
    A4 Quattro, vert Z, Jeep XJ
    Louisville, KY
    I would have the boots at the end of the steering rack inspected. They might be retaining all of the fluid as it's leaking out. If that isn't where it's going then I have no clue!
    1 more red A4, 3.0, 6spd Quattro...
    Now with a "free" Imola B5 S4 6spd
    Jan 24 2009
    2003 A4 Avant
    Averill Park, NY
    It's been a while, but now I know. the spew was the result of the power steering filter being completely and comprehensively clogged.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Quote Originally Posted by nfgusedautopart View Post
    thanks for the follow up post.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by kwimberly View Post
    X2! It's follow up posts like this that help to add to the overall knowledge base on the forums. Especially when there are unusual symptoms involved. (rep to you! )
