Results 1 to 9 of 9
    Veteran Member Four Rings 2001S4CT's Avatar
    Nov 17 2006
    Greenwich
    Idle and Tranny ?Question?
    Well everyone knows that S4 idle a little over 700 RPMs right?
    I just got my car back from doing a complete tranny replacement after the original went kaboom, and now the car idles a 1000 rpm. What can I do to fix that? Does it have to do with the transmission?
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Re: Idle and Tranny ?Question?
    Wow that is a little weird. Does everything work the way it should? The one thing that comes to mind is either through vag com they changed the idle, or they adjusted the idle torque. You would need to get on a vag com and see what the values are.
    Jun 14 2007
    2000 S4
    Connecticut
    yeah, there are values in VAG that can be reset... I would contact 3zero3 and ask if there is a reason the tranny is idling at 1000... maybe there is a reason
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    have u let the car warm up. cause on cold days or cold starts the idle is higher than normal until it starts to warm up. idle is supposed to be at 800, u can change it thru lemi but id contact the people who did the work first
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Nov 17 2006
    Greenwich
    Guys thanks for the inputs. Problem solved I brought it back to the shop and they saw that when the engine was lowered to swap the trans one of the wastegate valves was broken off. They replaced it and it is fixed. Car is Amazing now and my Torque converter Cel is GONE.
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Tell me you at least got a manual tranny.
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    who did your work on your car? I blew my tip trans and and sent it out to 517 trans for a rebuild, and I hope to have it back this week, the stock internals did not like the 400 + WTQ going threw it orginaly . After the trans is broken in I am going to have the car retuned for more WHP and WTQ,
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    Quote Originally Posted by S4_NE View Post
    What are they charging you if you don't mind me asking?
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    http://www.517trans.com
    the link above is the contact infor for the shop. ask for Sam, He know's the trans well,
    Mine is going to be over 3000.00 but under 4000.00 due to extra parts needed and shipping it, 517/Sam has a shipping compainy that will pick up and drop off the trans.
    Give him a call or E-mail, When all is done the trans should hold 450 WTQ with no problems, I hope to have my car up and running this week, PM and I will give you more info
