Results 1 to 24 of 24
    Veteran Member Three Rings audithisworld's Avatar
    Jul 17 2005
    02 coupe quattro 225
    morganville nj
    anyone have this intake?
    http://www.ngpracing.com/store/index...product_id=329
    wanna get an intake soon and im pretty sure this is the one i hear all the good about but just wanna double check
    225 ftw!
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    Re: anyone have this intake?
    Seems like a waste of $300 for some sound.
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    ^^ 2nd on that. you wont gain hp from an intake like other cars, as our oem one flows enough already for 300hp. the only good reason to put an intake on is to hear the diverter valve when you let off throttle. i bought a 5" aem dryflow cone with 3" inlet (oiled filters can make maf dirty/damaged), and the blinktekdesign.com heatshield. 55 bucks for the cone, and a bill for the heatshield. now when i cruise i turn down my radio so i can hear the turbo spool and the diverter valve open..... love that sound....
    anyway dont waste 300 bucks on something you can do for 150 for the same result. just my .02.
    and by the way if you do get a cone filter like mine. you MUST get a heatshield, as this will deflect all the radiant heat from the turbocharger and exhaust manifold and turn your hot air intake into an actual cold air intake. blinktekdesign ftmfw.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Senior Member Three Rings Spykce's Avatar
    Aug 06 2008
    Indiana
    the 150 option I think is better, the blinktek shield actually works. I'm not so sure about the EVOMS. I plan to go the AEM and blinktek route soon.
    Current Car: 2000 A4 1.8TQ Frankenturbo Build | 2012 Passat TDI
    History: C6 A6 4.2, B7 S4, Mk V GTI, Mk IV GTI Vr6, Audi 80, Audi 4000 Q, B5 A4 1.8TQ x 5, B5 A4 V6, Mk II Cabriolet x 4, B5 Passat 1.8T, Mk II Scirocco, Audi TT 1.8TQ, Mk III GTI Vr6, C5 Allroad 2.7T x 3, '86 VW Quantum Wagon
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Yea seems like the biggest waste of money ever. Just get a cone filter and a heatshield, but then ask yourself, why do you need it? It wont give you any gains.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    I had one lying around, but I think my roommate threw out the heat shield
    I'll sell you what I had left of it.. which is the U bend, the bracket, probably the cuppler. You'd have to buy a filter and heat shield (which is a waste of money imo.. once the air hits the turbo, any benefits are negated imo). Anyway if you're interested send me an offer.. I'm about to throw it up in the forsale section.
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    I gota carbonio biggest pos waste of money ever. Every time I run teh card hard it gunks the MAF. The filter flows air and dirt like a sieve. Twice i went 2 the track twice my MAF was beyond repair.
    Jul 17 2005
    morganville nj
    i got the car 3 years ago and still havent changed the air filter once. im the kind of kid who just wants the package and doesnt mind paying the extra money so i think im gonna buy it :) plus i want some more noise
    225 ftw!
    Veteran Member Four Rings Silverstreak98's Avatar
    Dec 11 2006
    Minnesota
    Quote Originally Posted by audithisworld View Post
    I hope you didn't leave the stock replaceable filter in there for 3 years.
    ~Brian
    1998.5 A4 2.8QT
    Veteran Member Four Rings tamadrumr88's Avatar
    Nov 03 2006
    lehigh valley pa
    A boost gauge is helpful for tests like this...
    Even if these filters/intakes don't produce any more power something can be said for gas mileage. For example, when my car was completely stock it idled around 23 on the vacuum side of the boost gauge. After installing a 2.5" high flow cat and borla turboback it dropped to ~21. As far as the intake goes I just have a K&N cone filter/bracket... after installing that my boost gauge reads 19 at idle (indicating the panel filter/stock airbox was a slight restriction even at idle)
    I've recorded several 35+ mpg trips (strictly highway driving in the summer), before installing the exhaust and K&N filter I could barely break 30-31mpg doing the same trips in past years I'm still using the stock heatshield too which everyone complains about (I just painted it black)
    Veteran Member Three Rings B5 SLPR's Avatar
    Dec 04 2007
    B7 S4 Avant
    So Cal/La Jolla
    I had the ABD on mine for awhile and just went back to stock. I miss the sound a lil but it feels like stock, swiss cheesed with a drop in filter runs better.
    "I like to party"
    VMR, Great Wheels, Great Company http://www.velocitymotoring.com/
    Senior Member Three Rings jayraudi9's Avatar
    May 05 2008
    Virginia skreets
    Quote Originally Posted by B5 SLPR View Post
    howd you like that abd intake? ive got a chance to get one for dirt cheap and was wondering about it
    B5 Battalion
    Dec 04 2007
    B7 S4 Avant
    So Cal/La Jolla
    It wasnt bad, but I def like the stock with air box mod better. i just had the heat shield that abd provided in mine and i think that if you had a really good shield it would be nice but if your gettin it straight from abd, def not worth the money
    "I like to party"
    Active Member Two Rings techniq's Avatar
    Nov 27 2007
    Raleigh, NC
    Quote Originally Posted by tamadrumr88 View Post
    You have any specific K&N model/part #s for your setup? Looks nice...I'd like to do the same with the blinktekdesign heat shield.
    [ 05 A4 1.8TQ :: APR Stg1+ :: SB Stg2 :: 3" Exhaust :: K&N :: FMIC :: Forge DV :: 18" Kyalami :: RS4 Sway :: STS Coils ]
    Nov 03 2006
    lehigh valley pa
    '97-99 1.8t take the K&N 57-0282.. I'm guessing there's no kit for the newer 1.8t's because the secondary air pump would require a small breather filter. It could be done, but there's no ready-made kit as far as I know
    Veteran Member Three Rings v1nyd's Avatar
    Jun 15 2008
    Long Island NY
    Quote Originally Posted by B5A4Kevin View Post
    Thank you I've been looking for a good reasonable priced heat shield for our cars and this seems to be perfect, definitely going to have to pick up one of those
    Jul 12 2007
    Massachusetts
    Definitely an autozone piece together intake with that Blinktek heat shield is the way to go. All of the other pre-fabbed intakes are too much money just to hear the woosh of the turbo.
    2020 SQ5
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    waste of money.
    home made or modded stocker is the way to go.
    Registered Member Three Rings
    Sep 30 2007
    has too much crap to fit a car
    Upstate, NY
    Once I forgot to put the "snorkel" pipe back on my car after changing the filter... actually sounded pretty cool... bet it sucked alot more hot air in though.
    Got extra sound for free... haha
    Nov 27 2007
    Raleigh, NC
    Looking at that K&N part and comparing it to LLtek style/design (http://www.lltek.com/aik_a4_B6.htm) it appears just the small breather filter is all that's needed. Looks like the dimensions for that piece are [1.5" mount x 2.5" base x 2" top x 1.5" tall], of course mount is the most important. So If I combine K&N #57-0282 and #RC-2290 I should have a complete kit? Does that make sense?
    If that's true then from AdvanceAutoParts the the total price tag would be $115 (the 57-0282 item is on sale down from $138.50 to $78.99). You can get a cheaper shorter breather filter from somewhere else (boostedtech sells the one for their kit separately currently on sale for $16 - 1.5" instead of 3" compared to the K&N part).
    Sorry for the extended questions, just trying see if I'm on track for piecing this self-made kit together.
    Apr 01 2005
    one wagon one truck
    Michigan
    I can't wait for summer to try some of these ideas.
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    I'm sure if you searched for evo ms intake, a bunch of results would have came up. This topic has been discussed over and over and over in the past years :|
    TEAM|AXION
    Established Member Two Rings twofaze's Avatar
    Jul 27 2008
    Fort Worth, Tx
    heat shield looks nice..
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    they meant to say 0% to 0% HP gain.
