i did a write up on the b6 diy turbo timer but cant for the life of me wire this gauge up, instructions seem a little confusing. says as follows verbatum,...
1. Red: 12V Ignition Switch
2. Green: Battery +
3. White: 12V Dash Lighting (please note that if you prefer the backlight to appear whenever the ignition is on, connect this wire to the 12V Ignition Switch")
4. Black: Vehicle Ground
obviously know where the black goes. but im confused with the green, white and red? would green go to the lower distribution block...black to the fuse box ground and red to the headlight switch?
