Ok here is the deal:
Car only boosts to 7psi....to the dot, nothing higher in any gear/rpm. (Should be hitting 18-20). Brand new VDO mechanical/manual boost gauge.
I went to try the tennis ball boost leak method, and when it got around to finding the PVC hose so I could clamp it off, I have NO IDEA where it is. There are too many damn hoses around the manifold. I pressured the system to god knows how many PSI, and watched the boost gauge, it went to a whopping 3psi MAX.
The car runs perfect. but only boosts to 7psi, in any gear. No spiking, nothing. Its like it was programed to hit 7psi.
At idle it is at 20-22 HG.
I do not own a vag-com system, nor do I know where to find someone with one.
I've only got access to a warm garage for the next 24 hours :(
heeeeeeeeeeelp!!!!!!
