Results 1 to 20 of 20
    Established Member Two Rings snowplow's Avatar
    Jan 21 2009
    Philadelphia
    BACKWARDS DV's???
    whats the deal with installing diverter valves for noise? any one actually know if it works???
    2000 stage 3- Audi S4
    Veteran Member Four Rings mrpeterparker's Avatar
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    Re: BACKWARDS DV's???
    sigh
    Lurker
    Registered Member Three Rings sc_flaw's Avatar
    Dec 18 2008
    2008 Ibis White a3 Sline
    toronto
    Search is your friend~
    Jan 21 2009
    Philadelphia
    Quote Originally Posted by mrpeterparker View Post
    sigh
    good input, thanks for all your help
    Jan 21 2009
    Philadelphia
    Quote Originally Posted by sc_flaw View Post
    searched it, nothing
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    The search facility can be tricky to use, it doesn't always accept certain keywords.
    Jan 29 2007
    08 S4 00 S4
    MD
    08 S4- Stock SOLD
    Veteran Member Four Rings NastyNogaro's Avatar
    Oct 31 2006
    2008 RS4 Exclusive/Premium
    Didn't you learn your lesson in the first thread?
    Don't do it.
    "Fazz" | Interactive Web & Application Developer | ig: @turbofazz
    2007 911 Turbo 6MT
    2015 Nogaro S4 DSG - Sold
    2008 RS4 Exclusive/Premium - Sold
    2000 Nogaro S4 6MT - Sold
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    mine are backwards (007A's), and I noticed no difference in sound, even with the Darintake.
    seriously though, search multiple times using different key words.. theres a 99.9% chance that what you are wanting to do is not original and has been discussed at least 3 times on here.
    you CAN run them backwards with ZERO problems (although the Audi Stealership decided that my backwards ones were not correct and told me "your aftermarket valves are installed incorrectly and do not work this way".. I asked them "o really, how did i drive here, and why does my boost gauge go into vacuum immediatly after throttle release then?" They kindly offered to switch them into "working" order for me for 60 dollars.. I lol'd)
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Veteran Member Three Rings s4nicetry's Avatar
    Nov 29 2007
    Calgary / Vancouver
    It will make no noticeable difference, just install them the way they were designed to be installed and call it a day.
    Veteran Member Three Rings Chknkatsu's Avatar
    Feb 08 2008
    2010 Wrangler Unlimited 6spd, bmx bike, 337 GTi (SOLD)
    Whitestone, NY
    Quote Originally Posted by snowplow View Post
    wat
    __________________________________________________ ______________________________________
    $4c@b
    "I like to hide behind my sunglasses and check out the underage girls."
    WGLYC
    S4SugarHips
    "my name isn't mike."
    Veteran Member Three Rings Auburnsky1287's Avatar
    Jan 06 2008
    Orlando
    Put them on backwards, and install the forge dv spacer (little metal disc). Then you get a nice little pshhh sound when you let off the throttle. They still function just fine.
    2001 Audi S4
    Vast Tuned Stage 3
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Whaa What? what is goin on ?
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Established Member Two Rings G.O.A.T.'s Avatar
    Jun 22 2007
    2001 S4 STG2+
    Ontario,CA
    I have the baileys dv's. When you really get on it, you can hear the slight and faint pshhh too. But you realy have to be listening and swiss cheeze the airbox
    Liberating Horspower...one mod at a time
    http://www.straferight.com/photopost...-jiggle-02.gif
    Jan 21 2009
    Philadelphia
    Quote Originally Posted by Auburnsky1287 View Post
    i cant find the forge spacer?
    Senior Member Three Rings eliTTe's Avatar
    Arlington, VA
    you will hear them decently with a open element filter/intake like the S-flo or evoms intake. I have the evoms cold air intake and can hear them with the windows up
    Then: 1985 Audi coupe GT, 1990 Audi 90 sport, 2000 Audi S4 stage 2+, 2002 Audi TT 225.
    Now: 2011 Audi S4
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    HKS SSQV......
    O wait, wrong car......
    Stick to normal DVs
    Jan 21 2009
    Philadelphia
    Quote Originally Posted by eliTTe View Post
    how do u like that intake ive been thinking about buying it
    Jan 06 2008
    Orlando
    They should look like those metal rings. My dv's came with all springs and spacers. It seems like you can also buy them in the forge DV tuning kit.
    Doing the Darintake mod will help as well.
    2001 Audi S4
    Vast Tuned Stage 3
    Veteran Member Four Rings S-Power's Avatar
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    ^ I have Forge 007 and just re-greased my DV yesterday and I dont have those spacers
    What is its function ?
