Results 1 to 26 of 26
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Running with unplugged N75
    Will i run into any problems running with my N75 unplugged? Here is my issue. If i run just the N75 at WOT i will boost 30+ PSI I hooked up a manual boost controller and boost comes on really hard even at 1/4 throthle and it's anoying. btw: Im running parallel with the N75.
    I would like to make a cut off swithch for the N75 and turn it off when im just crusing because with the N75 unplugged it boosts 9psi abd it's so much more smoother. I know that i will probably have a check engine light but that's not an issue since it's already on. If i want to go fast i just flip the switch and off we go.
    What's your take on this? BTW im stage 3
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    Re: Running with unplugged N75
    Is your boost gauge reading correct? IIRC , w n75 unplugged you should be seeing 6-7 psi.
    Regardless, yeah you can drive with the N75 unplugged as much as you want, I don't think it even pops up on the dash with a cel, but I can't remember.
    But my opinion is, rather than make the cut off switch, just buy another N75, they are only 175 bucks I think from audi?
    Or, just run your MBC standalone, and cap boost at 20 psi or whatever you want, then you're set, no overboosting.
    Veteran Member Four Rings AudiXS4X01's Avatar
    Nov 11 2006
    01 Audi S4-Santorin Blue
    Tri-State
    I have an extra N75 valve that I can sell u if you'd like, PM me if interested.
    Jan 03 2008
    Iowa
    Quote Originally Posted by Boris View Post
    Overboosting is not an issue anymore since i hooked up a manual boost controller and it's set at 20psi. My problem is that my car is very jumpy at take off boost comes on very hard and the car will jump. II i was running with very low boost like 9psi it's som much easier to control the car it's somewhat anoying because i would like to be able to take off smooth. If i want to take off easy i have to be very light on the throthle if i were to tap the pedal it will almost jump as if the pedal was pressed in 1/2 way.
    Jul 26 2008
    Jersey
    Did you ever fix your crazy vacume issue?
    Jan 03 2008
    Iowa
    Quote Originally Posted by spinny View Post
    Yes There was an inline checkvalve that was somehow broken.
    Jul 26 2008
    Jersey
    Quote Originally Posted by GetAwayFromMe View Post
    Good stuff! isn't it a great feeling when you fix something and actually have your car 'back' ??
    My car was suffering some WACKY electrical issues and now it's fixed - so stoked!
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    I run a MBC in standalone with my stage 3.
    Personally, I think you are best suited to getting a JHM in car manual boost controller setup which will allow you to crank up the boost when you want more. That way, you cap spikes and "power-up" when you need it.
    I remember of some one basically using solenoids and relays to trigger valves that would allow the driver to switch between parallel and manual.
    B5 S4 AWE Stage 3 - sold
    Jan 03 2008
    Iowa
    I ended up getting a different N75 valve and it still boosts 30+psi. Looks like gonna have to stick to a MBC from now on :/
    -02 F'in Silver. GT2560/s AWE, ER/s RS3 Wheels, KW/s and every other typical S4 upgrade.
    Jan 03 2008
    Iowa
    Quote Originally Posted by csre9 View Post
    Just turn the mbc a couple pounds down man.
    Run the n75 as well.
    And find the spot to safely run the mbc.
    Your boosting 30+ because its turned too many times..
    You probably misunderstood. I was running 30+ psi on N75 only. I tried a different N75 because i thought it was bad and causing my overboosting problem but it wasnt. I had to hook up a MBC to lower my boost to about 20psi
    BTW: Im rinning it in parallel with the N75
    Veteran Member Four Rings S4-ORCE's Avatar
    Apr 16 2007
    01.5' S4 ASP Tuned
    Long Island
    You shouldnt be boosting 30+ stop trying to band aid the problem with a MBC and fix it right.
    Jan 03 2008
    Iowa
    Quote Originally Posted by S4-ORCE View Post
    Well what do you think it should be done? I need to log the car and see what requested boost it. I need to purchase a vag com still to do that.
    Jul 15 2008
    2001 S4 silver sleeper
    Butler, PA
    Every solve your problem? It kind of sounds like mine... Check out this thread...
    http://www.audizine.com/forum/showth...ighlight=boost
    I'm going to try a new N75 as well...
    Veteran Member Three Rings rouellettea4's Avatar
    Apr 07 2005
    00S4STG3, 1995 Subaru Impreza, 96 A6 (blown HG)
    Holden/Worcester, MA
    My car does the same thing. It's the tune, we both run the same one. I am running a MBC in parallel with n75 and its fine. The part throttle builds boost very aggressively but its easy to get used to.
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    torn wastegate hose
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Senior Member Three Rings archimense's Avatar
    Jan 16 2006
    Vancouver, Canada
    If you are boosting to 30 psi with the N75, then either your tune is asking for too much boost, or your N75 doesn't work. Those are the only two things that explain your problem.
    Running the MBC in parallel will not allow you to boost higher than the N75 is requesting.
    Last edited by archimense; 04-29-2009 at 05:59 PM. Reason: Clarified running in parallel
    2001.5 Audi S4 stg 3
    K04s, 85mm MAF, 60lb injectors, custom software
    ASP DTS/Tru-Dual/Downpipes
    Stasis Tracksports/4:1 Centre Diff
    Neuspeed 19mm rear sway - CPP rear end links/tie rod ends/front upper control arms
    VAST ceramic clutch, RS4 pressure plate, JHM shifter
    RS4 engine/trans mounts, Stern rear diff/snub mounts 55 watt HIDs, Odyssey PC680 battery, Innovate Wideband
    Veteran Member Four Rings csre9's Avatar
    Feb 03 2008
    Stage 100 b5s4 hooked on meth, other money pits
    At work
    Quote Originally Posted by JDM EJ1 95 View Post
    torn wastegate hose
    Ding ding ding
    Dec 20 2005
    District 7
    could be a leaking wastegate hose, thats easy to check though, unplug the n75 and see how much boost you make, if its about 7 psi, the lines are fine...
    sounds like whatever file you're running is off to me though.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    ^^^ If you're not getting boost to the WG, you're going to run whatever the turbo's can give you (which is why you bleed off boost from the WG to run more boost).
    to the OP, try looping the boost/vac signal directly to your wastegate lines... If you do that, they should only be boosting ~7psi. If you're still boosting a lot you have an issue with the line going to the WG or the WG themselves.
    Jan 29 2009
    Quote Originally Posted by archimense View Post
    In an Audi you send more boost to the WG to run more boost. If no boost is sent to the WG then it is only the WG spring pressure that holds the WG closed.
    The S4 engine technical manual explains this.
    What you're saying is just plain untrue.
    Unplug the wastegate line on your S4 and tell me what happens. I'll be waiting.
    Jan 16 2006
    Vancouver, Canada
    Quote Originally Posted by NOTORIOUS VR View Post
    Yup, I'm wrong. I must have been smoking crack. Springs hold the wastegates closed, pressure is applied to the wastegates to open them.
    Not sure how I got that backwards. I'm going to check the technical guide again, because I believe it mentions they specifically designed the boost control to fail with minimum boost and not maximum boost.
    Jan 16 2006
    Vancouver, Canada
    You should log your requested boost, and your N75 duty cycle. That will give you some more info. N75 duty cyle of 100% is wastegates closed, duty cycle of 0% is wastegates open.
    Jan 03 2008
    Iowa
    I used a MBC to fix this problem. When i unplugged the N75 iT DIDNT BOOST OVER 7PSI AND I ALSO CHECKED FOR LEAK IN wg LINES AND IT WAS FINE. i THINK MY OVERBOOSTING PROBLEM WAS CAUSED BECAUSE MY EXHAUST. i HAVE 3' ALL AROUND.
    Feb 03 2008
    At work
    Dude that wouldn't change anything. LOL
    Jan 29 2009
    ^^^ It is possible that the tune you're tunning isn't sensitive enough for your setup I guess and it's reacting quickly enough for the boost spike (although unlikely). But if everything is working fine with the MBC just stick with that.
    The more likely scenario is that there is an issue with the N75 wiring and/or ECU output holding it all the way open (if you've checked the N75 duty cycle in VAG and that reads normal) regardless of what the ECU is asking for, or the ECU is commanding it to be open all the time for some reason (software issue).
    I just find it hard to believe that two N75's are bad, and I VERY highly doubt that this is caused by a 3" exhaust.
    Jan 16 2006
    Vancouver, Canada
    You should log your N75 duty cycle and requested boost, otherwise you are really just guessing.
