Results 1 to 14 of 14
    Veteran Member Four Rings psiaddict85's Avatar
    Dec 16 2008
    Cleveland OH
    ECU Software update???
    So I just spoke with the dealer who informed me that I have to bring my car in for some sort of software update? Will this update affect a chipped ECU?
    Veteran Member Three Rings barkerd427's Avatar
    Oct 04 2006
    2007 Audi A4 & a honda
    Princeton, NC
    Re: ECU Software update???
    It will delete your programming and you will have to get it reprogrammed.
    2007 A4 2.0T S-Line Quattro / Deep Sea Blue / Black Leather Interior / Nav / Heated front seats / Xenon head lamps / APR Snub Mount / RS4 Pedal Set / RS4 brushed aluminum grille / RS4 rear sway bar / RS4 parking brake handle / Xenon match interior lighting / SOON Custom fog light grilles with S6 LEDs and RS4 mesh and brushed aluminum trim, just need to find the trim
    Dec 16 2008
    Cleveland OH
    so does anyone know anything about this so called update? Or is just audis was or clearing chipped ECUs?
    Oct 04 2006
    Princeton, NC
    Audi has updated it's software several times. They are just standard updates to adjust aspects of the ECU.
    Stage 2 Banner Advertiser Four Rings
    Jul 11 2005
    04 Audi S4, 04 VW R32, etc....
    Auburn
    Quote Originally Posted by barkerd427 View Post
    typically to correct for any programming errors, bugs, or to recalibrate a control strategy that will increase the operation reliability or correct a previously unknown issue.
    Its no big deal, all oem's do it and your ecu should be reflashed for free with no worries.
    Oct 04 2006
    Princeton, NC
    Thanks Keith for adding info that I couldn't. Also, it will be free, but you may have to pay for the labor.
    DUH! an Audi
    los angeles, CA
    depends where you go, they will charge you labor to connect a computer to your car and flash it some do it for free.
    I havent heard about this new update, what is it for, what year, etc etc.
    -randy
    Jan 09 2009
    FL
    Quote Originally Posted by Keith@APR View Post
    Dec 16 2008
    Cleveland OH
    I have an 06 and I'm bringing the car in for an oil change and they told me they have to do it once the car is here.
    Veteran Member Three Rings Subaru71's Avatar
    Jan 15 2008
    2010 DGM Impreza WRX
    Chino Hills, CA
    Keith, I don't know about these Audi ECU's so how many times can you safely flash it?
    2008 Phantom Black TQM
    Deactivated Three Rings
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Quote Originally Posted by psiaddict85 View Post
    My car was in the dealer yesterday for replacement of a low fuel pressure sensor (CEL came on) under warranty. Car was there whole day even though they finished early. They also did a complimentary 27-point inspection (whatever that entailed), washed and vacuumed it, but never mentioned verbally or on the printout that an ECU update was done. I must wonder if this only affects certain model years.
    Mind you I had a 35,000 mile service done just before Christmas and it was not done then either.
    Now my questions are for the APR folks -- if Audi reflashes the ECU with new software, and the car is then re-chipped, how does the chip handle the new Audi software? Does APR also re-design their chips to take advantage of new Audi updates or, if not, will the perfomance of the chip suffer / improve as a result of these Audi updates?
    Dec 07 2008
    Harrisburg, PA
    Quote Originally Posted by wayneB7 View Post
    This is a good question the APR chip won't be any different unless APR says its been changed and it will work with the factory update just as it did before like nothing has changed.
    Dec 16 2008
    Cleveland OH
    So how does this work if my car was already chipped when I bought it and audi reflashes my ECU. Thats BS because I would have to pay $600 again to get it reflashed.
    Jan 13 2009
    Pittsburgh
    Would you still have to get the car chipped again if you had a flip-switch or SPS unit?
