well, generally i've known true CAI to usually have a snorkel, or the filter relocated to an area where true outside (cold) air is available. The available aftermarket intakes seem just like filter/housing upgrades/inlet upgrades, but not really a true CAI. GSG created what looks like a true CAI. Maybe our stock intake should also be considered a CAI, more so than aftermarket, because the airbox/filterbox is fully enclosed with a snorkel that feeds from the outside, which is why we usually get better performance with stock. Aftermarket intakes try to take advantage of the the built in stock snorkel, but since they are not a full enclosure, they get heatsoak regardless, because the cone filter is taking in air from every which direction which air leaks in the "heatshield" that those CAI manufacturers provide and so you still get a fair amount of that thousand degree contact air.
Then take what the last 2 guys said, and yes, cold air intakes make a difference. Oxygen molecules are chemically necessary for combustion. gasoline could not burn without it. More oxygen = better combustion. Colder = denser oxygen mass is gaseous form.
