Results 1 to 2 of 2
    Veteran Member Three Rings dewey527's Avatar
    Mar 10 2008
    '02 a4 1.8tq, '05 tahoe
    Puyallup
    right rear passenger door...
    sometimes the light comes on and sometimes not any ideas?
    mods - not enough for me and way too many in my wife's opinion
    K04, Revo "Stg2", PODI Boost Gauge, TT225, fmic, Forge DV, Tantrumwerks 300cell HFC, Neuspeed Exhaust, Stasis Touring Suspension, Spec Stg2 & LWFW, 034 RSB, Neuspeed SS, Neuspeed Snub, Neuspeed TIP, B6S4 front brakes, Tyrolsport Kit, 6K HID, Yellow Fogs, 20%, CC
    Senior Member Two Rings TahoeA4's Avatar
    Jan 08 2009
    Kingsville, TX
    Re: right rear passenger door...
    Are you talking about the puddle light, under the door that shines on the ground? If so, take a screwdriver with tape wrapped around it and pop the light out and check that the bulb is in there securely. You might have to bend the metal holder a little bit so it makes solid contact with the metal parts on the lightbulb. You might want to pull the fuse first so you don't short out anything, I think it is fuse #23.
