Results 1 to 6 of 6
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Reuse exhaust gaskets? Is a leak probable?
    I know that some people reuse the gaskets between the turbo and cat/test pipe and between the cat/testpipe and downpipe... any leaks after reuse? This would just be short term for a few months before I swap the turbo out for a BT kit. I have one new one but for 2-3 months... Id rather not pay for another because I just experienced the $20 rapage at the dealer for the turbo/cat gasket. Fookin eh that's pricy. $67 for three gaskets and 13 manifold nuts.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Re: Reuse exhaust gaskets? Is a leak probable?
    I've reused mine, would be in serous debt if I had to replace all the gaskets every time I've pulled the turbo out.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    My shop reused one of them when they did my testpipe. The other was rusted to crap.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    you can reuse them... just use your best judgement on the condition of them.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Audi Skate Snow View Post
    bingo.
    I have only replaced my HFC to downpipe gasket once. I've had my HFC off my car four to five times since. The gasket is fine.
    I have re-used my cylinder head to manifold gasket twice now. The gasket is intact and fine. If it is separated then get a new one.
    I did away with my manifold to turbo and my turbo to HFC gaskets. metal on metal. One less thing to blow-out. Its holding strong thus far.
    With the resources you have, Jon... Clean up the manifold to turbo and turbo to HFC flanges and don't run a gasket on those two interfaces. A very strong and flat table works well (I used a 3/4-1" glass table that was zeroed and flat). Tape a good sheet of 200grit metallic sandpaper to it and work the parts over the sand paper slowly and securely. Gradually build up to 300 or 400grit. You'll see the high spots taken off and the surfaces will be perfectly flat for use with no gasket. I did this on those two flanges in December and its holding strong.
    NordLock washers are your friend on the turbo to manifold interface. Copper locknuts are your friend on both sides of the HFC and the engine to manifold interfaces. Use new copper locknuts.
    -Doug
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    I agree ---use your best judgement, I reused mine the first time around but then I blew them all out, I got better gaskets and its been all good since then
    Some fast things and some slow things
    ~Josh~
