Results 1 to 4 of 4
Thread: bad MAF = esp?
    Established Member Two Rings nycats4's Avatar
    Nov 13 2008
    04 s4, 01 se-r
    nyc
    bad MAF = esp?
    This problem started happening for about 2 weeks now. Every time I drive the car the esp light comes on after a few miles, and resets if I start the car only to reappear again and so on. A few times while squeezing into a parking space the abs along with the esp light both went on. There is no check engine light. Its been really cold here in ny for the past weeks so maybe that has something to do with it. I've read other posts referring to similar problem and there appears to be some linkage between the MAF and ESP. I ordered a new bosch MAF element for about 99$ and since I already have the 5 point hex needed to remove this thing it shouldn't be that difficult. I'm just curious if any members here think it might have something to do with the colder air, or do you guys have this similar problem in warmer areas as well. Thanks
    Senior Member Four Rings ...Mark...'s Avatar
    Oct 03 2008
    Murdered out 04 S4..
    Atlanta BITCHES!!!
    Veteran Member Four Rings serumk's Avatar
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    Re: bad MAF = esp?
    FWIW, my MAFS was acting strangely, needed to be replaced, and never triggered the ESP light. Lots of CELs, though.
    Veteran Member Four Rings drew's Avatar
    Jul 27 2004
    E60 M5 Gone: 996TT stage 3, E46 M3, B6 S4
    Orange County
    Re: bad MAF = esp?
    Quote Originally Posted by nycats4 View Post
    i've never had this problem but before you replace it, try cleaning it.
    you can buy CRC MAF Cleaner at most autoparts stores
