Results 1 to 4 of 4
    Registered Member Two Rings 1.8G's Avatar
    Jul 09 2005
    99 1.8t, stage III
    Sacramento
    Boost/Hesitation issue...
    Ive recently started to drive my a4 again, it has been a while because i have been away the last 3+ months. When i got back, i had to replace the battery, but after that it was running alright, with the exception of the following: My boost gauge shows that my turbo is spooling up at the normal rate (GTRS @~3350), but i dont get any real power until about 5k, when it comes on really fast and sudden... Is this a boost leak, a bad dv? I have never felt this before, very odd.
    4 turbos, 2 clutches, 1 addiction and 0 money.
    Established Member Two Rings Jkilla71's Avatar
    Jul 31 2008
    01 325XI 99.5 A4 B5 Avant,67 Triumph T100r, 70 CB350, 82 Honda XL185s, 12 TU250 Cafe, 14 Enfield GT
    Allentown, Pa
    Re: Boost/Hesitation issue...
    I had a boost leak in the 90-elbow before the suction pump but the characteristics were the exact opposite. I would have boost until I hit the gas hard.
    How about the wastegate sticking??
    Jul 09 2005
    99 1.8t, stage III
    Sacramento
    Im not overboosting or anything though, just holding a solid 19psi from 3.5k up, but its not until 5k that i see power.
    Jul 31 2008
    Allentown, Pa
    Just brainstorming but could it be the N75 valve causing the ECU to act crazy. If it were that I think would you would get CEL
