Results 1 to 6 of 6
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    What will cause one rotor to wear faster than the other?
    My passenger side looks to be wearing alot faster than my drivers side. The wheel spins freely with no hangup on the brakes.
    Senior Member Two Rings BB2001S4:Tim's Avatar
    Oct 04 2006
    NY/NJ/CT
    Re: What will cause one rotor to wear faster than the other?
    Caliper...possibly
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    On one of my older cars I had one of the studs that hold the caliper to the brake assembly bent which caused the brake pad to wear faster and uneven. Could check that???
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Veteran Member Four Rings Quattrocket's Avatar
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    could be a seized or sticking caliper, sliders may need a re-greasing?
    MITCH
    "Audis are like strippers. They only work when you throw money at them."
    FORGE MOTORSPORT DVs*K04 TURBOS*034 TURBO INLETS*STAGE 3 SOUTHBEND CLUTCH(MANGLED PP MOD)*
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    has your master cylinder ever been bled? maybe theres a clog somewhere?? idk.. worth a try bleeding all the fluid out. its not hard either.
    Account Terminated Four Rings
    Aug 06 2007
    audi, subaru, dodge, ford
    Truckee, CA
    a few things, air in a line, a frozen piston, kicked and stuck pad or a faulty abs control module that is lightly engaging a caliper for EDL
