Results 1 to 12 of 12
Thread: Oil Cap Gasket
    Veteran Member Three Rings revbjeff's Avatar
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    Oil Cap Gasket
    Where's the cheapest place to find the gasket/seal in between the oil cap and motor. Mine is chewed up and drips oil into the 4 cylinder spark plug hole.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: Oil Cap Gasket
    Then you need a valve cover gasket.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    Re: Oil Cap Gasket
    No the gasket that touches the oil cap. This is on the 2.8 the oil links in through the top because of the angle and position of the oil filling hole.
    Dec 04 2007
    New York, NY
    Re: Oil Cap Gasket
    Quote Originally Posted by revbjeff View Post
    Thats not going to cause oil leaking into the spark plug hole. I may suspect oil MAY seep out from that gasket but you'll have oil reside outside the oil cap.
    You need what was shown above ^ V.C gasket and oil plug seals.
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    Re: Oil Cap Gasket
    See it drips off of where you put oil in at and on to the cylinder 4 plug wire then drips down on top of the plug. I know what a valve cover does is. The thing I'm talking about is under the plastic engine cover. It is rubber and surrounds the cap.
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: Oil Cap Gasket
    Go to a VW or Audi dealer. It's a few bucks.
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    Re: Oil Cap Gasket
    Ok to help show what I am talking about I took some pics. The part number is chewed up and I can't read it. Every couple days I clean the oil off or I will get many CELs about misfiring (obviously). Thanks the suggestions and your time.
    The first pics so you where the "gasket" is normally and now it drips into the cylinder 4 oil plug.
    This pic is me pointing at the culprit.
    And this one shows you the gasket removed.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: Oil Cap Gasket
    Thanks for pointing the obvious. Dealership will be your est best for this part.
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    Re: Oil Cap Gasket
    Cool I figured the pictures would help clear things up.
    Dec 04 2007
    New York, NY
    Re: Oil Cap Gasket
    never realized cyl 4 is that close to oil ?port?
    Pictures clarify alot.
    Hope you fix it.
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    Re: Oil Cap Gasket
    Quote Originally Posted by flyromeo3 View Post
    Hope you fix it.
    I thought how close they are were ridiculous also.
    Yeah I'm going to go to the VW stealer today hopefully they can help me. Last time I called them they said I had to have a part number because they are a VW Dealer not an Audi Dealer
