Results 1 to 17 of 17
Thread: Revo Stage 2
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    Revo Stage 2
    I did some searching but I couldn't find exactly what I'm looking for. I am looking to go Revo stage 2 and was wondering if you need to have a high pressure fuel pump in order to do so. I currently have intake, exhaust, diverter valve, will that be enough to run stage 2 without getting fuel cuts?
    I'm asking this because I was looking at Revo's website and this is what they list for the bolt ons you need to go stage 2.
    An aftermarket performance exhaust system
    A 4 bar fuel pressure regulator
    An optional aftermarket diverter valve
    And a Revo SPS
    The fuel pressure regulator is throwing me off because I don't think it's the same as a fuel pump, or is it? I know APR offers stage 2 which doesn't require a fuel pump and then they have a fuel pump file to take you to stage 2+. Hopefully Revo does it the same way. Hopefully someone who's 100% sure can tell me soon since I'm going up there on my lunch break. Thanks in advance for the help.
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Senior Member Two Rings A4CE1's Avatar
    Feb 10 2008
    06 A4 2.0, 03 Wrangler, 96 XJ
    Westchester, NY
    Re: Revo Stage 2
    i was flashed with revo stage two with just a cat back exhaust. I experienced mild fuel cut at that point. nothing too bad, the performance was still amazing. as soon as i added the test pipe the fuel cut got much worse for some reason. And you are correct, revo has a program specifically for the fuel pump. that is what will take you to 2+.
    VW Touareg V10 TDI. Don't mess.
    Past: Stg. 2+ B7 2.0T, B6 A4 1.8T, Allroad 2.7T 6spd (<-monster), Chevys, Jeeps, and a Nissan.
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you, Body kits and decals are how much of a mess you leave on the wall.
    Mar 07 2008
    Audi A4 B7
    VA
    Re: Revo Stage 2
    Thanks for the quick response... I modified my search a little bit and was able to find this.
    Quote Originally Posted by Geoffafa@Wolfcars View Post
    i was flashed yesterday by wolfcars with the new release of the revo 2+ file, and when it flashed yesterday i really didnt feel much difference, maybe a little more up top in the rpm range but nothing to write home about. now when i woke up this morning and came to work, it was like whole other monster, i was on the highway spiking 26psi holding 22 and at 5500 rpms it was still holding over 18psi, something i have never seen before in my car, holy crap, i must hand it to revo the new map on that file is SICK! another job well done by them, and i do reccomend anyone who has it available to get it, because i doubt anyone on here has it yet... and if u do chime in with your impressions
    That pretty much answers my question...
    I think I'm going to go with the Stage 2 and hope for no fuel cuts. I'll probably upgrade my fuel pump in the next few months to the AWE pump and get the fuel pump file from Revo. Does anyone know how much a fuel pump installation will set me back?
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    Re: Revo Stage 2
    Yea..Revo make STAGE 2 + for the hpfp file...I also so fuel cut more once I added the testpipe BUT this is prob due to the higher performance I received as well.
    HPFP and Revo STAGE 2+ file i heard makes a world of difference. I plan to do it ASAP.
    Veteran Member Three Rings JGreen76's Avatar
    Jun 05 2008
    Houston, TX
    Re: Revo Stage 2
    I am pretty sure that the fuel cuts after adding the testpipe are due to the turbo baing able to spool faster,,,,hence needs a little more fuel..
    '21 RS5 Sportback-Tango Red - Black Optics Carbon Package
    '20 R8 Spyder Performance - Kemora Grey - Black Optics Carbon Package
    PAST:
    '21 SQ5 - Quantum Grey
    HIS: 2019 Glacier White TTRS Black Optics///HERS: 2019 Tango Red TTRS///2017 Macan GTS///2014 Q5 3.0T Glacier White with Black Optics///2015 S3..........:::Glacier White, APR Stg3::::.......///2013 MK2 TT Roadster///2007 B7 A4 S-Line 3.2
    IG: TwoCarGarage_HOU
    Veteran Member Four Rings bblume's Avatar
    Dec 20 2007
    06 avant. 92 Gti. 07 X3. 14 Sq5
    Colorado
    Re: Revo Stage 2
    I"m planning on going
    stg II in the next week or two
    SUBSCRIBED! AND WILL PLAN ON POSTING UPDATES!
    14 Sq5
    02 Eurovan
    04 DBP R32:.
    92 Gti-TDi 1Z (sold)
    06 AVANT S-line QMT6 (Just sold it!!)
    07 BMW X3 (given to the in-laws
    Veteran Member Four Rings Sal_B7's Avatar
    Dec 11 2007
    2005 A4 2.0T Quattro 6Spd
    San Diego, CA
    Re: Revo Stage 2
    Yeah Revo Stage 2+ is awesome!!!! Very Happy Customer!!
    '05 A4 2.0T Quattro MT APR Stage 3
    2008 APR Holiday Giveaway Winner!! Thanks APR!!
    FRRG Southern Ring
    Xbox Live ID: Sqzn2zz
    Veteran Member Four Rings italia8287's Avatar
    Jul 23 2008
    New York
    Re: Revo Stage 2
    when you guys added the hpfp how hard was your mpg hit? i know your pushing more fuel so miles til empty def had to take a hit.
    2007 QMT6 Ti S-Line
    NorthEastRegionDubs
    Dec 20 2007
    Colorado
    Re: Revo Stage 2
    What is the fuel cut experience like?
    Does she buck?
    When does it happen?
    TIA
    14 Sq5
    02 Eurovan
    04 DBP R32:.
    Mar 07 2008
    Audi A4 B7
    VA
    Re: Revo Stage 2
    Car is now officially stage 2!! It's nice to see my boost gauge climb back up to 20psi again... I had gotten used to the stock car so it's like getting flashed for the first time again. yippeeeee
    Active Member Four Rings juggernaut201's Avatar
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    Re: Revo Stage 2
    stage 2+ is deffenitly fun and as for install i ppaid 120
    *JUGGERNAUT*
    (Revo Stage II + HPFP File, AWE Cat Back, DMH Performance Electric Cutout, Forge Diverter/Spacer, Carbonio Intake, AWE FMIC, Snub Mount, RS4 Motor Mounts, S4 Big Brake Kit, E Code TestPipe, KW Variant 3 Coilovers, H Sport F & R Sways, KMD Fuel Kit, KMD Cam Follower, NGK Colder Plugs, Boost Gauge, South Bend Stage 3 Clutch, ECS Light Weight Pulley,Custom Inlet Pipe, 034 Street Mount, Apikol Rear Diff Mount, JHM SS Kit W/ Linkage Upgrade And Weighted Knob Lo Jack
    276hp/331tq
    Dec 11 2007
    San Diego, CA
    Re: Revo Stage 2
    Quote Originally Posted by italia8287 View Post
    Well yeah it does take a big hit if your pushing it but if your easy on it, then it stays the same. I havent been able to get over 350 miles per fill up since i have gotten the upgrade. Its hard to lay off when it just picks up and goes.
    Dang, im going to be hurting once i get my stage 3!!! Im sure it will be worth it though!! lol
    FRRG Southern Ring
    DUH! an Audi
    los angeles, CA
    Re: Revo Stage 2
    stage 2 is at a minimal a test pipe, which is what is really needed for stage 2.
    Exhaust, hpfp, etc is an option, but recommended. Stage 2+ is HPFP
    I am stage 2 and no hpfp, but have everything else.
    Dec 11 2007
    San Diego, CA
    Re: Revo Stage 2
    ^^Get a fuel pump already dude!!! lol
    FRRG Southern Ring
    DUH! an Audi
    los angeles, CA
    Re: Revo Stage 2
    I want too, but I dont feel like checking for cam lobe every 5k miles
    Dec 11 2007
    San Diego, CA
    Re: Revo Stage 2
    you dont need to do it every 5K APR says every 10K :)
    Have you been in a stage 2+ car? Trust me you will want to convert!!
    Dont mean to threadjack. PM me back Randy.
    FRRG Southern Ring
    Dec 20 2007
    Colorado
    Re: Revo Stage 2
    So now i'm at Stg II as well!!!
    It's good stuff for sure..spools like a BAMF!
    However I think it is indeed just to patch the code thrown by the TP
    because my boost is still right around 20psi (just like before the Stg II flash)
    so I"m guessing, (as suspected) that this modding will never end!
    It's time to work towards the HPFP
    although no fuel cut yet????
    Does anyone know if the settings on F B and T change when stg II flash happens? I think mine are at 7 4 and something?
    What is the diff between 1 and 2 with these settings if any?
    14 Sq5
    02 Eurovan
    04 DBP R32:.
