Results 1 to 8 of 8
    Senior Member Three Rings Greek Yayo's Avatar
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    correct name for this part
    i gota red b6 a4 and the very bottom all around is gray. i want to make that match the car all around. whats the correct name of that bottom gray part??? i would paint it but my body shop guy said the paint wont last on it due to the material.
    thanksssss
    Sep 13 2008
    Western Chicago Burbs
    Re: correct name for this part
    those are called lowers. and they can be painted. get a new body shop guy
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    but its textured wuldnt it look a lil different???
    CO
    Textured? Hmm, mine are smooth, both the lower door trim and the side skirt. If it is in fact textured then it would probably need to be sanded first.
    Quartz Gray '11 S4 Prestige || Sprint Blue '06 S4 Saloon - Sold || Denim Blue '02 A4 1.8T - Total Loss || Laser Red '98.5 A4 1.8T - Sold
    In Limbo Two Rings
    Jan 17 2009
    Nor*Cal
    They are not textured, they are painted with a matte grey finish.
    Painting will hold up just fine, most Audis 2004+ have painted lowers now to match they rest of the car.
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    it will hold up fine.. good but will it match the car paint?? like ino it guna b same color but will the plastic look be diff?
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I had mine painted last year and it looks great.. they will have to color match/blend it for it to look perfect. Basically tell them you want the lowers to be color matched/blended with the rest of the car if you want it to look OEM. They will take the Audi color code from your car and go from there. If they don't understand what you are asking then find a good shop that does. Also if you have had any paint work done before to any panel that is above the lowers you should tell them that as well to get it matched correctly. I found out one of my panels had been painted before I owned the car and it doesn't match perfect.. good luck
    Veteran Member Four Rings EYE4SPEED's Avatar
    Jan 14 2008
    Macan Turbo, Cayenne Diesel, Audi Jr Quattro
    West Coast of Michigan
    They'll match if your bodyshop is good. Don't go Maaco or else it won't match. Pay the extra for an Audi Certified repair facility. They will warranty the paint work.
    FS: Audi TT 225Q Roadster
