Results 1 to 2 of 2
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    DTC error code...Help!
    I just scanned my car and I got a errorcode from the engine.
    16825 P0441 Evaporative Emission Control System - Incorrect Purge Flow A.
    What does this mean? Nothing wrong with the idle or anything.
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Nov 24 2007
    Tromsoe, Norway
    Re: DTC error code...Help!
    Found this:
    16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
    Possible Symptoms
    Malfunction Indicator Light (MIL) active
    Possible Causes
    Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
    Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
    Evaporative Emission (EVAP) Canister Sealing faulty
    Pipes between Tank Breathing and Throttle Body leaky/blocked
    Possible Solutions
    Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
    Perform Output Test
    Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
    Perform Basic Setting
    Check Pipes between Tank Breathing and Throttle Body
