Page 1 of 3 123 LastLast
Results 1 to 40 of 83
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    Built ko4 or stock block rs6
    What would you guys go with? I'm actually thinking ko4 is that crazy, or should I go with rs6, I'm gonna do my best to get rs6 but should plan for ko4 anyways
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Active Member Four Rings
    Dec 11 2006
    Boston
    Re: Built ko4 or stock block rs6
    lol. neither make sense
    you dont need to build a k04 car
    it would be very wise to build an rs6 car
    Stage 3+ RS6's
    Jan 21 2007
    01.5 Silver Avant
    dc
    Hmm, I guess I can't run that much higher of boost on ko4s compared to rs6 ko4s max psi is what compared to rs6s
    Dec 11 2006
    Boston
    You can max out boost on K04's without even coming close to fubar'ing a rod.
    Stage 3+ RS6's
    Jul 26 2008
    Jersey
    Don't be a p000say! run 25psi on stock rods - it'll love it!!
    Jan 21 2007
    01.5 Silver Avant
    dc
    LOL, I was running 24psi, looks like I'm slowly building rs6s, jared can get rosten rods right??? How do those compare to any other one
    Dec 11 2006
    Boston
    Jared used to be able to get Rostens, I don't know if he still can. You could go with Intergrated Engineering or "034". I personally went with Pauters.
    Stage 3+ RS6's
    Jan 21 2007
    01.5 Silver Avant
    dc
    An issues with pauters??? Clearance or anything weight? Heard anything about the 034 ones?
    Jul 26 2008
    Jersey
    did you blow your motor with 24psi or you just want to build up?
    Jan 21 2007
    01.5 Silver Avant
    dc
    Motor was fine building another 2.7 I have
    Veteran Member Three Rings Chknkatsu's Avatar
    Feb 08 2008
    2010 Wrangler Unlimited 6spd, bmx bike, 337 GTi (SOLD)
    Whitestone, NY
    Quote Originally Posted by casawhites4 View Post
    boost doesn't determine power. it's all the matter of flow.
    18psi on ko3 and 18psi on ko4 and 18 on GTs is all different. You want the most flow of compressed air that you can get to the motor...i hope this makes sense
    __________________________________________________ ______________________________________
    $4c@b
    "I like to hide behind my sunglasses and check out the underage girls."
    WGLYC
    S4SugarHips
    "my name isn't mike."
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    skip Ko4's. You could run Rs6's on pump fine, but ramp up torq later in the rpm band.
    Just no race gas on the rs6's if you leave the block stock.
    BUt forget either option. No more pussyfooting around, just make a GT kit, get one from VAG, I was talking to ALex up there, very reasonably priced and exchange rates in our favor right now, I think 1.30 to 1 USD...
    Some type of gt turbo casa, thats what you need, build the engine, gt terbs.
    Veteran Member Four Rings AB18's Avatar
    Dec 17 2004
    US
    I have a reeeaaaal nice piece of land you may be interested in. :)
    2001 S4 6sp...has a few goodies...and JHM shifted
    Tons of parts for sale..
    GIAC A box ECU for sale-350shipped.
    http://www.audizine.com/forum/showthread.php?t=170072
    Jan 21 2007
    01.5 Silver Avant
    dc
    hmmm, interesting then
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    if i had a spare 2.7 id go with IE rods and GT's.
    fucka journal bearing turbo when you can bolt up dual bb garretts now days
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    rs6. the rs6 turbos are worth the extra 500 bucks because even if you run on the stock rods you can push 400whp easily. why max a k04 car when you can have an efficient rs6 car? the k04s will be at the upper limit and you will be shelling out major cash for for rs4 parts and minor gains down the road if you get tired of the power. If you do want more power in the future then Rods will cost the same as the rs4 components that the fastest k04 cars are running and will net much more gains.
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
    Senior Member Three Rings epyx's Avatar
    Jul 08 2008
    B5
    Salisbury, MD
    Quote Originally Posted by Boris View Post
    How much were you quoted?
    Veteran Member Four Rings Korben007's Avatar
    Nov 08 2007
    00 Celica Supercharged, 02 S6, 04 S4 Avant
    Lake Tahoe, CA/NV
    Quote Originally Posted by wdbdy2000s4 View Post
    i like where your heads at!
    Current Rides:
    2000 Toyota Celica GT-S Supercharged - 2008 Audi A3 VRT(SOLD) - 2003 Audi RS6 Avant - 2013 Audi Q7 Prestige
    2000 Audi S4 Stage 3(SOLD) - 2008 Audi TT 3.2 (SOLD) - 2002 S6 Avant Manual w/ S8 PES Supercharged - 2015 Porsche Cayman GTS
    1990 Audi Coupe Quattro(SOLD) - 1993 Toyota MR2 Big Turbo(SOLD) - 2001 Audi S6 Sedan (SOLD)
    @audijedi
    Oct 08 2008
    MA
    Quote Originally Posted by Korben007 View Post
    thankyou good sir. I don't know why everyone is saying go GT. he clearly states he plans on a stock block for now so the idea of a gt is out of the question. On top of the rods, GT kits need built heads, tubi manifolds, bulletproof clutches, endless seals and gaskets and a ton of other shit which puts the kit at 2x the cost of a stock block rs6 or k04.
    Jan 21 2007
    01.5 Silver Avant
    dc
    how much faster is a stock rs6 s4, vs stock k04 s4.
    Oct 08 2008
    MA
    rs6s are an extra 500 bux for the turbos and you get around 75-100 hp extra. Now look at an OTS stage 3 kit where you get about 350whp. Getting that extra 100 horses from the k04 will surely cost more than 500 bucks. The rs6s will have a little more lag, maybe a couple hundred rpms but there ability to hit higher boost and hold it makes it worth the money. If you go with rs6s you can throw in rods later for 1500 with labor and seals and such and you'll be able to hit 28-30 PSI and hold 27 to redline. A k04 is like a hair drier over 21 PSI because of the small hotside. PM ubermidget, he went from a marc tuned stage3 to vast rs6s. the 10secS4 kit is still local and it can't touch the VAST car which has stock rods.
    Jan 21 2007
    01.5 Silver Avant
    dc
    interesting, very interesting, im just debating on what to do now! damnittt
    Account Terminated Four Rings
    Nov 30 2006
    01.5 pearl white S4 6speed
    annapolis, maryland
    rods, ko4, nitrous : ).. Id prolly build the motor and then save up for rs6's.....and add nitrous
    Jared can get rod's and is an awesome guy to deal with.
    Nitrous is like adding Michael Jordan to your 3 on 3 backyard basketball game.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by deb38 View Post
    ballin'
    -Doug
    Dec 11 2006
    Boston
    It all really depends on your tune. We have all seen Jackson (PJ K04) slaughter an ASP, fully built RS6 car.
    Stage 3+ RS6's
    Jan 21 2007
    01.5 Silver Avant
    dc
    I'm going with vast for my tune period. Love them and there work
    Veteran Member Three Rings ubermidget's Avatar
    Dec 08 2006
    Boston, MA
    night and day difference between the two....trust me its worth the money, i dont care what keyboard racers say, cant judge until your sitting in the car for a first hand experience
    RS6's ftw
    EPL Stage 3 Aquamisted
    Jan 21 2007
    01.5 Silver Avant
    dc
    Ãœber what's done to your engine? His vasts tune treating you?
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    quite interesting. I want to see whos selling these rs6's for 500 more than k04s. Not this 1200 or 1300 more.
    Dec 08 2006
    Boston, MA
    my setup:
    Vast rs6's
    ASP 3" dp's
    AWE twin 1
    AWE ic's
    custom 85mm maf
    60#'s
    stock airbox
    034 intake spacers
    Vast tune
    stock motor
    Jan 11 2007
    Salt Lake City, Utah
    Agree with most of what you say, except for the specifics on the prices. KO4's are what, $2200-2400 and RS6's are $3550-3600 right? A little more than $500 difference And even with the least expensive rods, IE rods at $850 a set, with all of the necessary seals/bearings and the labor of tearing the engine, balancing the rotating assembly, and assembing the motor again, you're likely to be over $1500 for that as well.
    Otherwise, I agree for sure:)
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Jan 21 2007
    01.5 Silver Avant
    dc
    Quote Originally Posted by ubermidget View Post
    my setup:
    Vast rs6's
    ASP 3" dp's
    AWE twin 1
    AWE ic's
    custom 85mm maf
    60#'s
    stock airbox
    034 intake spacers
    Vast tune
    stock motor
    That's basically what I'm trying to do. But was worried I wouldn't enjoy the rs6 as much as built ko4s but it seems like I'm way off on that, what would you change on your setup and what clutch and flywheel
    Dec 11 2006
    Boston
    A built K04 setup isn't going to give you anymore power. Building the block is going to ensure that you don't put a whole in it. Unfortunately K04's can't put down that much power, therefore making it pointless.
    The only benefit I see you getting from a built block on K04's, is the fact that you have a fresh motor.
    Stage 3+ RS6's
    Dec 08 2006
    Boston, MA
    the only thing I want to at the moment is add W/M and maybe an x-1 intake along with some revisions to my tune. Im running a CM stage 3 w/ lwfw from my old k04 setup...still holding strong, but i dont drive the car in the winter so the test will be in the spring
    eventually down the road im going to build up a 3.0 and put some billet wheels in the rs6's
    gl on the build whichever you may choose, you wont be dissapointed w/ the rs6's
    Nov 30 2006
    annapolis, maryland
    Hole*
    Veteran Member Four Rings lnferno's Avatar
    Oct 14 2006
    Rocky Mountains
    What about going with K04/RS6 hybrids?
    Nov 30 2006
    annapolis, maryland
    Quote Originally Posted by lnferno View Post
    unless you buy blown ko4's it isnt worth it.. Might as well go rs6's. around the same price if not cheaper
    Nov 22 2008
    01.5 S4
    Michigan
    Go Single Or Go Home =]
    Apr 27 2008
    silver s4
    LI
    We should get a group buy on RS6's to bring them down some.
    Nov 30 2006
    annapolis, maryland
    Quote Originally Posted by haus4 View Post
    GL
