Results 1 to 18 of 18
    Veteran Member Four Rings Beelzeebub's Avatar
    Oct 08 2008
    B7 S4
    Quick Q on wheels
    Can a wheel that's sized 19 x 8.5 fit onto a stock everything B7 S4? I know a 19 x 8 can but 8.5?
    Veteran Member Three Rings J.the W.'s Avatar
    Aug 30 2007
    2014 CP M5, 2006 Pathfinder LE
    Az.
    Re: Quick Q on wheels
    Yes. I'm running 19x8.5 Sportec's with 245-35 tires and I'm lowered. I don't think you'll have any problems.
    Senior Member Four Rings Bravest NY S4's Avatar
    Jan 18 2009
    BKNY
    No rubbing on a complete turn??^^^
    I'LL BE BACK.........
    Never forget SWAY
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    Completely fine if the offset is correct. Offset should be +35 for perfect fit on 19x8.5 with 245/35 rubber
    Dec 05 2006
    So. Cal.
    Actually, a perfect offset for the 8.5" is a +38.
    The BBS CH 8.5" +35 shod with 245's rubs so you're gonna need that extra few mm's. You can run all the way down to a +32 on an 8.5" wheel but you gotta take out the fender bolt, keep it at a decent ride height and stiffen up the suspension a little bit to keep the rubbing at a minimum.
    Aug 30 2007
    Az.
    Quote Originally Posted by Cargo8 View Post
    ^^ I forgot that important piece of info^^ I've got a 35 offset as well.
    No rubbing on turns. I do rub a bit when I go over a dip in the road too fast sometimes.
    Veteran Member Four Rings JOS4AUDI's Avatar
    Jul 09 2008
    2008 RS4, 2012 S4, 2013 Allroad
    So Cal
    thats exactly what im running looks perfect and performs nicely.
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    19x8.5 ET32 and approx 25.5 ground to fender height with no rubbing.
    Veteran Member Three Rings norsecarnut's Avatar
    Sep 15 2008
    2 Land Rovers, BMW E61 mt6
    Quote Originally Posted by MOFSTEEL View Post
    Are you getting a different Audi or just selling this one off? I suppose if you had another one already it would be listed.
    On tires and wheels, do you think there is much merit in the idea of sticking with 18's simply for sake of durability? Say an 18x8.5 so contact traction is equal.
    I've had troubles on 19's before and those were even rft's
    2008 S4 Avant mt6 Dolphin - APR Full exhaust / Escort 9500ci-stealth install / backup camera / aux-in & ipod & cd / 35% ceramic / 2" hitch class 2 / Nokian WRG2 / HID fog / Stasis high-bias center diff
    AKA: jwest
    Dec 06 2006
    I have no rubbing with this setup?
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Quote Originally Posted by jwest View Post
    No more Audi's for now. Buying a house and I already have another car. Im sure i'll be back in an Audi in the future.
    There are 19s out there that are going to be very durable.
    No matter the size there is no such thing as indestructible. Either find yourself a well made set of rims that will set you back a few k's or buy some lessor brand for cheap and not worry about shelling out big money if something were to happen.
    I've been very lucky and have had no troubles with my 18s or 19s.
    (knocks on wood)
    Dec 05 2006
    So. Cal.
    Running a 235? 245's rub.
    Dec 05 2006
    So. Cal.
    So your tire is a 245? What tire are you running and what is your ride height?
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    235 Vredestein Ultrac Sessanta's which are supposedly a "true" 235.
    Dec 06 2006
    Tire 245/35/19 PS2s, although I'm still @ stock ride height, so that is clearly the diff
    Sep 15 2008
    (knocks on wood)
    I suppose you sold the 19's you had?
    I wouldn't mind a stiffer suspension but I don't want to be any lower. This car is for all purpose and some roads to trail heads are not so nice to lowered cars.
    AKA: jwest
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    No, still have them. Took them off the car when I decided to sell it.
    They will be for sale as soon as the car sells.
    Oct 08 2008
    B7 S4
    thanks for the input guys. appreciate it.
