Results 1 to 9 of 9
    Registered Member Two Rings ImAudi's Avatar
    Jun 05 2007
    2001.5 Audi S4
    Holland, Michigan
    Blinker is playing games....
    So I just purchased a 2003 Audi A4. Im experiencing a blinker problem. When I turn on the left turn signal on it works just as it should, when I turn on the right one, It turns on the left turn signal to 2 blinks then switches over to the right? Then after I complete the turn and the blinker goes off, it will blink to the left two more times. Anyone else experience this, or does anyone know how to fix it? Thanks a lot.
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    Re: Blinker is playing games....
    People have had this problem on here and It seems to be common. Mine did the same for quite a while. The blinker stopped being erratic about the time this school term started and has not given me trouble since. No Idea way.
    I would suspect the problem has to do with the connections inside the mechanism.
    Jun 05 2007
    2001.5 Audi S4
    Holland, Michigan
    I'll take a look into it, otherwise i'll have them check it out at the shop. Any more info would be much appreciated. Thanks
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    My actual turn signal stalk was the cause for this,it did that then eventually only made left turns.. was a pita to get out and replace, check the connections inside the column..Good luck
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Deactivated Three Rings
    Jun 10 2007
    Toronto, Ontario, Canada
    Very common problem. Do a search and you should be able to find some discussions on this. I get this issue sporadically as well. From what I understand, you need to replace the turn signal lever/stalk. My situation hasn't gotten to the point where it's happening so frequently that I need to replace it yet but I know one day I will have to do it!
    Jun 05 2007
    2001.5 Audi S4
    Holland, Michigan
    Yeah, it's been fine today, so I guess I'll wait it out too!
    Jun 10 2007
    ^ Summer thread revival!
    Has this erratic turn signal issue gotten worse over the past 6 months or so?
    I was ordering parts unrelated for my B6 from GenuineAudiParts the other day and decided to simply buy a new turn signal lever stalk (http://www.genuinevwaudiparts.com/pa...layCatalogid=0). I should be getting it within the next week.
    Found this great DIY thread on removing/replacing the turn signal switch as well as the entire steering column: http://www.audizine.com/forum/showthread.php?t=138299.
    Veteran Member Three Rings BerNur's Avatar
    Jan 31 2009
    Brandon FL / Astoria NY
    some of them are caused by the emergency relay unfortunetely mine was the stalk as well too much work to replace..
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    I get ghost clicks on mine, which was common on VW's as well. I did a lot of research on turn signal issues, and often just getting in the column and using contact cleaner on all the internal workings has fixed some of the probelms. I just ordered a long skinny 8 size Torx to get in there.
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=150345113291
    I am going to try and clean the contacts before I go through the headache of pulling all that stuff off to replace the turn signal assembly.
    Other times it was the hazard switch that was messing things up, and that might have even been a recall on some VW's.
