Results 1 to 16 of 16
    Senior Member Three Rings JK35's Avatar
    Apr 08 2008
    97 B5 TQM
    SW Florida
    VIS Racing body kit, need advice instaling front bumper
    I bought a VIS Racing ("RS4" knockoff) Full Body Kit. The rear bumper and side skirts went on quite nicely and with minimal fitment issues. the front bumper however, has me perplexed. It is nothing more than a fiberglass shell with no mounting points... I have my factory bumper taken apart down to the crash bar (which is cut and modified, bracketry and re-designed structural elements welded/bolted to accomodate BIG ass FMIC)
    Now the nifty snap fit parts are seperated from the bumper cover, and the bumper cover is cut down to where it almost fits within the new fiberglass "bumper"
    I'd like to know how others have mounted and installed these things.
    I've narrowed it down to a few options from what I can figure out, but am far from certain which is the best course to take
    -A. fiberglass the OEM structural plastic (snap together mounting system from original bumper) inside the new fiberglass bumper (shell), hope I have it right and that it hasn't warped out of position. -install as the original installs
    -B. hotglue, chem caulk and or poly adhesive the new bumper shell over the original bumper (new 'glass bumper is the same size as the OEM, so if I install "over" the OEM, it isn't long enough Cut the original's ends down? cut the original in the center removing about an inch of overall length???) -aye caramba! what a mess!)
    -C. redesign an entirely new mounting system (for which I haven't a clue where to begin) The advice I've rec'd from the manufacturer and seller constitutes "screwing" the new shell on -to what I have no idea, as I can't find any suitable locations for "screwing" the new fiberglass shell on, and without some structural reinforcement underneath, there's no way this is going to hold up under normal use...
    Whatever I end up doing, I think reinforcing this thing with a couple more laminations of fiberglass is absolutely mandatory...
    Perhaps you know a better way???
    I'd sure appreciate any advice for getting this fiberglass "bumper" installed as best as it can possibly be installed.
    thanks in advance!
    PS i know... polyurethane, Rieger Racing and so on, but that's out of the question. I need to install what I have for now
    Apr 08 2008
    97 B5 TQM
    SW Florida
    Re: VIS Racing body kit, need advice instaling front bumper
    here's the new "bumper" pulled over the trimmed down OEM bumper
    here's the OEM structural parts
    as you can see, pulling the new one over the top of the OEM urethane is going to pose some obstacles
    Surely I'm not the first B5'er to install one of these
    + any advice or even links will be greatly appreciated
    Veteran Member Four Rings 4A Play's Avatar
    Jun 12 2008
    Allentown PA
    Time to run to the hardware store to pick up some aluminum stock to make some brackets.
    Self made, NOT Mommy paid.
    2001 1.8 qtm, GT2781R, 680cc Siemens, 3" turbo back, Autopower, Mafless Stage 3 Unitronics, Tial 38mm external wastegate, STS, Corbeau seats
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    i don't know about the whole "using the old bumper" idea. there's gotta be a way to make new brackets, while removing the old bumper shell......
    just wont look right, (or fit right) if you put it over the oem shell......
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Sep 01 2005
    maybe cut this end peice off and fiberglass it to the new bumper?
    BTW, what is that a 3071?
    Veteran Member Four Rings Starting's Avatar
    Feb 13 2004
    98 A4 1.8t
    Central, NJ
    glue it to the reinforcement bar and then one screw in each fender. take off the old bumper just leave the bar.
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    I'd say you should sell it and just find a used reiger ABS bumper....the problem with these fiberglass RS4 knock-off is that it requires a TON of work to get it to fit, which will involve additional fiberglass to essentially remold the bumper....I bought one of these 3 years ago had planned to mount it. But every bit of information I found on it was too discouraging (some ended up paying several hundreds to body shops to get them to fit, and they STILL didn't look right).....cuz it seems like your problem is that the bumper isn't lining up with the fenders, and even if you made brackets, it would still stick out a fair amount.......Sorry if this isn't helpful at all, but its just an idea. Sell that thing on AudiForums, like I did, and find an ABS plastic one
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Sep 01 2005
    Quote Originally Posted by JK35 View Post
    I'd sure appreciate any advice for getting THIS fiberglass "bumper" installed as best as it can possibly be installed.
    thanks in advance!
    i hear you, but i think he stated that he knows what you just told him.....
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    This is what you need to do. Keep the bumper support on. Put some strong adhesive on it. Place the bumper into the spot that you want. Then tape it to your car with painters tape till the glue cures. Take off tape, put one screw on each side up into the fender. Process complete.
    Quote Originally Posted by Starting View Post
    Oct 06 2004
    Minnesota
    zing...
    man of the year award??
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Is it the fact that I've been gone for a little while or does anyone else notice that Starting is back?
    Damn, last time I remember hearing from you was when you had to quit your widebody thread due to some necessary time off.
    Senior Member Two Rings beAu4's Avatar
    Nov 23 2008
    98.5 Audi A4, Ford Ranger Baja
    San Jose CA
    just run the re bar witht he kit over it
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Get rid of it.
    Drilling hole in your fenders is a chep-out, and just encourages rust where the screws go in.
    Besides, the fibreglass will eventually crack where the screws hold it to the fenders, unbelievable the amount of vibration the front end of a car suffers in everyday use.
    It's not uncommon for folk to try saving a buck, buy cheap knock-off fibreglass, then spend so much time trying to get it right, or paying a shop to do so, it ends up costing more than a used OEM S4 bumper, and sometimes as much as a new one.
    Apr 08 2008
    97 B5 TQM
    SW Florida
    Thank you for the advice.
    I used the original rebar, made some reinforcement bars (3 per side) and fiberglassed a 5" piece of 1/2' x 1/2" box tube in each end ( "ear" ) and devised a clamping / mounting system to attach to the fenders. from the point of reading replys, and starting over on the front "bumper" I have about 2 1/2 hours invested in this piece of crap, but it looks OK for now.
    And "For Now" is about as long as the fiberglass kit is going to stay on my car... I have bigger fish to fry, before purchasing a complete Rieger kit (which is what I really want on the car) like finishing up my turbo install -no cheaping out there In fact, here's a pic of my new snail to give an idea as to where my priorities lie ( and why my budget is so shot to shit, that I ended up putting a $220 fiberglass body kit on my car
    thanks again for all the help guys!
    By the way, the Rieger kit... HOW do the parts attach? do they come as "shells" like the VIS kit I bought? or do they have structural elements just like the original pieces?
    are the rear bumpers "half add-ons" or are they complete replacement bumpers?
    Veteran Member Four Rings oneohone's Avatar
    Nov 13 2007
    Baur TC2 / W221 S600
    Dallas, TX
    Wow that looks great. I have a similar bumper in storage, I think I might install it after all.
    Daily - 00' Audi A4 1.8t Quattro 5mt Laser Red Avant
    In.Progress - 00' A4 2.7t Swap (w/ K04's)
    Oct 25 2006
    oregon
    Horrible kit.
    Ordered one when I got in a wreck. VIS Racing is a joke. Had so many issues I kept the sideskirts because I do like the style, and sent everything else back.
    $220 for the kit? Maybe we're thinking of a different company. Exact skirts I have though.
