Results 1 to 13 of 13
Thread: Funky Smell...
    Veteran Member Three Rings Monkey77's Avatar
    Oct 30 2007
    2005 Audi A4, Tiptronic.
    new jersey
    Question Funky Smell...
    Lately I have been getting a rather pungent almost like a burning smell when I turn my heat it. I am trying to figure out if it might be the heater core, maybe just a funky cabin filter. Filter was just replaced 5k ago, so I am not sure where else it can be coming from. Any feedback on what this may be?
    thanks.
    side note: anyone know where I can get a more resilient oil pan?
    Joey D.
    " You can't be lucky all the time, but you can be smart everyday."
    Dec 19 2007
    York, PA
    bump...I'm getting this now any suggestions please?
    Veteran Member Four Rings 32_d3gr33s's Avatar
    May 14 2009
    '16 Tiguan TSI, '08 Suburban, '02 Ninja ZX-6R, '06 Ninja 650R
    West Michigan
    that is one hell of a bump!! at least we know you searched!
    Sorry i've got no help though...
    I could write something cliché and insightful, but that would be too cliché and insightful.
    **-Anthony-**
    2003 A4 3.0 Pearl White | Autopilot V2 | Airlift Slam Series | Koni Sport Shocks | Pioneer X920BT | Kenwood 9105 | Kenwood 8405 | Infinity 6030 | 15" Alpine Type R | Ram Air Intake | Adams Rotors | Air Horns | Oettinger | Varrstoen Wheels| ABT Grille | 5% Tint | Build Thread
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    have you checked the filter again?
    2019 SQ5 Prestige
    Junior Member Two Rings mjwkr's Avatar
    Apr 19 2011
    SE Michigan
    I am not claiming to be an expert but I have been doing some homework on this topic as I have the same issue. Most often people point to a valve cover gasket leak (oil hitting exhaust causing burning smell). I haven't verified it on my own car yet but here is the DIY for the valve cover gasket replacement: http://www.a4mods.com/index.php?page...alvecover.html
    Veteran Member Four Rings bman005's Avatar
    Sep 06 2011
    2015 Silverado, 2012 A4 Avant. Former; 90 Corrado, 97 Golf, 05.5 A4, 2010 Tiguan
    Harrisburg, Pa
    Yeah, it is most likely an oil leak from the valve cover gasket or cam adjuster seal. The oil drips right onto the exhaust
    New Build, 2010 Tiguan. Details to com
    Aug 26 2005
    If it smells like dirty socks from your dash vents, it is most likely fungus growing in the A/C evaporator core. Run the heater/A/C in Auto ECON mode, that stops refrigerant flow through the evaporator core allowing it to dry out. You can also spray a full can of Lysol into the fan intake with the blower fan running on HIGH speed manual, with the filter removed, to help kill any fungus. Cover the dash vents with paper towels taped in place first.
    Vorsprung durch Technik
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    Honda HRX
    Penna.
    The plastic PCV line at the back of the head has probably deteriorated and come apart.
    Does it seem to get better or go away when you turn the Recirc. Button on?
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    Quote Originally Posted by bman005 View Post
    x1
    Veteran Member Four Rings iamshayan's Avatar
    Jan 13 2010
    Toronto Canada
    I actually laughed out loud, I will have to give this a try.
    thanks!
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Photobucket ruined all my posts.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    A burning smell is probably the valve cover gasket leaking onto the exhaust manifold. I had the same issue a few years ago. New VCG cured it. I had a severe case of the "smelly sock" syndrome on my '97 Passat VR6 when a mouse decided top make a nest on top of my cabin filter.
    Jan 13 2010
    Toronto Canada
    At least it was just a mouse
    LOL!
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Dec 19 2007
    York, PA
    its the valve cover...i found 2 threads when i searched. this one, bumped it, then read the other and OG suggested valve cover gasket...mines leaking....again. i think its the 7th time.
