The plastic housing that goes through the trunk body (bottom of the housing) won't budge for me. I have everything apart; everything exposed; I cut off the little nubs that might hold it to the inside, but it won't even wiggle! I can't pry it off for fear of damaging the lock/light housing. The new one looks like it will just slide in but the old one certainly doesn't slide out! Dremel is next! While using a chisel, I removed enough plastic to see that a bigger screw is coming from behind the assembly, which seems to mean that then entire lock/light housing has to come off! How stupid is this! Who designs these things - or over-designs them. This means the lock housing has to be removed - totally absurd! Just to change a damn bulb holder, a bulb holder!
