Results 1 to 22 of 22
    Veteran Member Four Rings Quattrocket's Avatar
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Clutch wont disengage after stage 3 install
    Alright so the car is completed finally, I try to move the car and when i push the clutch it won't disengage. The pedal is sitting close to the floor and I can feel a fair amount of resistance but it just wond disengage the clutch. What could be the problem? I'm going to try bleeding the slave and maybe replacing it if that dosen't work. any ideas experiences?
    MITCH
    "Audis are like strippers. They only work when you throw money at them."
    FORGE MOTORSPORT DVs*K04 TURBOS*034 TURBO INLETS*STAGE 3 SOUTHBEND CLUTCH(MANGLED PP MOD)*
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Re: Clutch wont disengage after stage 3 install
    Can you engage all gears with the car off?
    How about with it on?
    If you can get into all gears with it off, but have a lot of difficulty getting it into 1st and especially reverse with it on, then it's the forks on your pressure plate.
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    if it goes in gear with car off, and not while running its the slave cylinder.
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    I can engage all gears except reverse with the car off and none with the car on. sound like the slave cyl i guess?
    MITCH
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Sounds like you didnt put your slave in properly. So your clutch isnt disengaging when you hit the peddle.
    Also, did you feel resistance when you put the slave into the hole in the tranny? It should of went in a little then you have to use a good amount of force to push it in the rest of the way. Also you should feel the fork in the hole with your finger. If you can angle your self at like a 35 degree angle down from the hole, you should be able to see the cup that the end of the slave goes into.
    Jan 18 2009
    95 A6
    Des Moines,Wa
    trans may have to come back out, like the last post said if you did not get the slave in properly & you stepped on the clutch(let me guess it was heavy & then dropped) you may of shot the rod out of the slave & its jammed! post what you find
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Quote Originally Posted by phit View Post
    When i stepped on the clutch it clicked 3 times on the way down to the floor then came back half way, where it stayed. It never dropped to the floor it just stayed at the half way point where it still seemed to function. It still has lots of pressure when pushing the pedal to the floor but it just dosen't disengage. I don't think the rod shot out because it still acts like it used to before the stage 3 swap just doesn't have the same range of motion to it.
    MITCH
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Quote Originally Posted by haus4 View Post
    Yeah there was lots of resistance, I had to get my dad to push it it while I tried to thread the bolt, eventually we had to wedge a small pry bar behind it in order to get enough force to seat it.
    i felt the fork and everything as well.
    MITCH
    Veteran Member Three Rings awdbiturbo's Avatar
    Apr 20 2004
    01.5 S4 /95.5 URS6/72 914/
    Boston
    transmission does not need to be removed to install a slave cylinder.
    2001 Audi S4 Stage 3+/996TT with mods/HURACAN LP610-4 VORSTEINER NOVITEC VF ENGINEERING / 22 AUDI RSQ8 NARDO CARBON/22 RS6 NARDO BLACK OPTICS IE EVENTURI CTS
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    It happened to me when i got my motor back in. I pushed the clutch in and nothing. I called up a friend to help me bleed the clutch and everything was good afterwards.
    Mar 12 2008
    B8.5 S4
    San Jose, CA
    sounds like theres air in the system
    bleed the clutch some more
    2015 Audi S4
    2007 Audi RS4
    2002 Audi S4
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Thats so good to hear! thanks guys. I'll give it a shot.
    MITCH
    Mar 12 2008
    B8.5 S4
    San Jose, CA
    yeah bleed a lot
    it took my friend a day to do it
    2015 Audi S4
    2007 Audi RS4
    2002 Audi S4
    Nov 13 2007
    denver
    Use a power bleeder in addition to a buddy pumping the pedal. It took me 1.5hours for the clutch alone. It's a pain.
    Apr 27 2008
    silver s4
    LI
    It def sounds like you put in the slave in correctly. So I would say you need to bleed the system more. I would gravity bleed it over night then do the pump way after that.
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Is it possible to reach the slave without pulling the engine forward? I just put everything back together I really don't want to pull it apart again.
    MITCH
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by Quattrocket View Post
    unbolt the subframe rear bolts. let it drop as much as you can... put an engine hoist on the heads and a jack under the oil pan. access the slave cyl from the drivers side wheel well. thats how i did mine
    if youre not bleeding it correctly it will take forever.
    it takes 2 ppl. pump clutch, hold to floor, open valve on slave, repeat. should pressurize with in 10 minutes. oh and keep fluid topped off
    Apr 03 2007
    Fort Nelson, B.C.
    ok well i figured id just jump in on this thread instead of starting a new one.
    today i went out for a rip after installing a set of tracksport c/o's into my car. i headed out to the twisties for some fun ( i live near the mountains) all was pleasent until i came to a big straight and decided to try some launches and 1-2-3 shifts... i went thorugh the gears about 3 times and all was fine. when i stopped to go for a 4th run i couldnt get the car into any gear.
    at first i thought something in my shifter assembly had come loose, as i just installed jhm shifter and linkage at the same time as the tracksports. i shut the car off and it went into gear. so holding the clutch in i started the car and even though the clutch was depressed it still seemed as if it was in gear when starting..
    anyhow after crusiing for a bit in third and playing with it i realized it was not my shifter that was loose it was definately the clutch not disengaging.. so now after reading this thread im guessing it has something to do with my slave cylinder. i know it was properly installed as it was working fine up until this point... do they just die? or could it have become loose and pooped out? trying to get some ideas before i start pulling things apart...
    cheers!!!
    2001.5 S4 - stage 2+ w' APR, piggies, ASP true-dual, darintake, Southbend, Fidanza, Tracksports, ASP DTS, 18" BBS RX-II's, AWE center vent, CC mod w' H7 HID.
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Sounds like the slave died. sorry. not a fun repair.
    MITCH
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Could be that after a bunch of launches some air ended up in the slave, best thing to do is to bleed it and see if the problem changes. If the slave pops out or goes bad your pedal would be on the floor.
    Apr 03 2007
    Fort Nelson, B.C.
    yea see my pedal feels perfectly fine.. it goes in and out all the way in both directions... ??? where exactly is the bleeder screw for the clutch? right on the slave cylinder itself??
    Jul 07 2004
    socal
    Quote Originally Posted by slkdik View Post
    Yes its right on the slave. If this doesn't change anything it could also be that the top of the throw-out bearing broke causing it to be shorter and this would mean the fingers are not being pushed in far enough to release the disk.
