    Veteran Member Four Rings slimmj0k3r's Avatar
    Jul 31 2005
    Arizona
    Talking 18' Wheels that Will Clear 370mm BBK??
    I've done a search but couldnt find any results. I'm going to be upgrading to Stasis/Alcon 370mm BBK and i was looking for 18' wheels that will clear these. Most threads i've seen people are running 355's.
    Thanks.
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: 18' Wheels that Will Clear 370mm BBK??
    Sorry. we don't carry any wheels that would clear that big of a kit
    Jun 14 2005
    Anaheim, CA
    You should pick out a wheel, print out a caliper template and test fit it behind the wheel before buying. That would probably be the easiest way of testing to see if it would have any caliper to spoke or caliper to barrel clearance.
    -Charles@VMRWheels
    www.vmrwheels.com
    Brandon @ VMR Wheels
    Dec 15 2008
    Miami,Fl
    19's???
    Jul 31 2005
    Arizona
    Quote Originally Posted by COR Wheels View Post
    19's???
    i've got a set of 19's for the summer, i need something for winter,19s are too big for the winter for me. I'd rather run some 18's with a bit more meat on my tires
