Results 1 to 40 of 49
    Active Member Three Rings AP-Specialties's Avatar
    Mar 15 2008
    A few Audis
    Independence, MN
    Parting out: 2001 S4 Avant 6-speed Santorin Blue
    We continue to bring in inventory to provide you with a wide range of available used parts...
    We have just received in a new parts car! It is a 2000 S4 Avant Quattro with a 6 speed manual transmission. The car has about 100K miles on it, and was involved in a rear end accident. We were able to start, run, and drive the car around--the engine runs great.
    However, after inspecting the car, the following items were found to be damaged, faulty, or untestable
    -Rear Hatch
    -Rear bumper
    -Rear Right Tail Light
    Note that we have most of these parts available in our regular inventory, so if you're looking for one, browse our eBay store or shoot us a PM or email at [email protected].
    On to the price list! Note, we have almost 900 A4 parts listed online here, this is just a small summary of the parts we can and will sell! If you see it, we sell it!
    SOLD
    so far:
    Bumper
    Cluster
    Center console
    Drivers Seat
    Fog Lights
    Climate Control
    Radio Cage
    Steering Rack
    all 4 O2 sensors
    Side Skirts
    Cargo Cover
    DS fender
    DS Door
    central lock pump
    front fender liners
    driver door handle
    driver door felt
    Buyer pays shipping on everything, we will ship to Canada. Domestic shipping is UPS Ground and varies from $10-15 for most items to anywhere in the lower 48 states. Contact us for a quote if you live elsewhere.
    Note, the list below is a general overview of pricing for common items that we currently have in stock.
    Engine
    Complete 2.7T Engine w/Wiring Harness & turbos $1400
    6 speed Transmission - $1800
    Timing Belt Covers - $25/ea
    Belly Pan - $50
    Throttle Body - $150
    MAF w/Sensor - $100
    Power Output Stage (POS) - $60
    Coil Packs - $20/ea
    Fuel Rail - $40
    Fuel Injectors - $15/ea
    Engine Mounts - $40/Ea
    A/C Compressors - $50
    A/C Condenser - $50
    Radiator - $50
    Radiator Core Support w/o Fans - $150
    Radiator Cooling Fan (Electric) - $60
    Viscous Fan Clutch (w/o Fan) - $40
    Viscous Fan Wheel - $20
    Starter - $50
    Alternator - $50
    Oil Cooler - $30
    Power Steering Cooler - $30
    Power Steering Pump - $75
    Differential - $150
    O2 Sensors - $40/Ea
    Coolant Reservoir w/sender - $30
    Wiper Motor - $30
    Wiper Linkage - $50
    Washer Spray Nozzles (Headlight) - $40/Ea
    Washer Fluid Reservoir - $40
    Washer Fluid Pump (Main) - $40
    Washer Fluid Pump (Head Light) - $40
    Shift Linkage (6sp) - $80
    Air Filter Box - $50
    Air Filter Box Ducts - $20/Ea
    Fuel Pump - $55
    Fuel Sending Unit - $30
    Drive Shaft w/Carrier Bearing - $185
    Clutch w/Flywheel - $175
    Brakes/Suspension
    ABS Speed Sensors $40/Ea
    Front Brake Calipers w/Carriers - $160/EA
    Brake Booster - $40
    Brake Master Cylinder - $40
    Brake Fluid Reservoir - $25
    Front Rotors - $50/Ea
    Tie Rod Assy- $40/Ea
    Control Arms $40/Ea
    Center Differential - $350
    Axles Rear - $75/Ea
    Axles Front - $100/Ea
    Rear Knuckles/Knee Assy w/Hubs - $50/Ea
    Exterior/Body/Lighting
    Front Bumper Assy – Great condition with lower grills $550
    OEM S4 side skirts- $150 each
    OEM Avus 17” Wheels - $550
    Driver's side Mirror Housing (No Glass) - $50
    Passenger's side Mirror Housing (No Glass) - $50
    Grill (Badged) - $100
    Window Frame Assy With Windows (no Motor) - $75/Ea
    Side Windows (Glass Only) - $50/Ea
    Window Frame Assy W/O Windows (no Motor) - $25/Ea
    Front Fenders - $100/Ea
    Door DS Front - $100
    Door DS Rear - $100
    Door PS Front - $100
    Door PS Rear - $100
    Exterior Door Handles - $40/Ea
    Fender Liners - $30/Ea
    Moon Roof Assy Complete (Glass) - $150
    Front Bumper Shocks - $25/Ea
    Door Weather Stripping all four doors - $20/Ea
    Rear Left Tail Lights - $100/Ea (Left side only)
    Tail Light Bulb Holders - $30/Ea
    Interior/Electrical/Stereo
    Sport Wheel w/ badge- $160
    Instrument Cluster - $125
    Beltline Trim- $170
    Climate Control w/heated seat controls - $125
    Central Locking Pump - $100
    Cruise Control Module - $60
    Airbag Module - $80
    ABS Computer - $100
    Shifter Knob Black Leather - "Sport" - $50
    Shifter Boot Black Leather - $30
    Bose Symphony Radio - with Code - $125
    Bose Speakers - $50/ea
    Black Avant Pillar Trims A,B,C black- $50/ea
    Black Avant Headliner with Sunroof cut-out - $100
    Dash - $100
    Passenger Air Bag - $100
    Sunroof Switch Panel w/Lights (Good Condition) - $60
    Front Driver's Seat (Silver Leather) - $250
    Front Passenger Seat (Silver Leather)- $200
    Rear Seat - $200
    E-Brake Handle - $30
    Door Pulls Black (no switches) Good Condition! - $30/Ea
    Black Sun Visors - $45/Ea
    Column Switches/Stalks $40/ea
    Window Switches - $10/Ea
    Interior Door Handles Black/Silver Good Condition - $30/Ea
    Sunroof Motor - $75
    Window Motors - $40/Ea
    Window Regulators - $40/Ea
    Kick Panels - $20/Ea
    Heater Box Complete w/Heater Core, A/C Evaporator and Fan Motor - $100
    Blower Motor Fan Assy - $60
    Rear Window Deck w/3rd Brake Light - $50
    Tilt Steering Assy. w/ignition and Key - $60
    Center Heater Vents (3 total, sold separately) - $15/Ea
    Side Vents - $15/Ea
    Rear Vents - $15/Ea
    Black Overhead Grab Handles - $15/ each
    Front Seat Belts - $50/Ea
    Rear Seat Belts - $25/Ea
    Interior Floor/Door Trim (from Front to Back) - $50
    Exterior Black Door Sills - $50/Ea
    Please check out our feedback posts here:
    http://www.audizine.com/forum/showthread.php?t=130524
    http://www.audizine.com/forum/showthread.php?t=248038
    http://www.audizine.com/forum/showthread.php?t=198448
    Return Policy- All used parts sold come with a 7 day non dead on arrival warranty. We will replace or refund all faulty parts 7 days from the date of purchase. All other returns are not accepted.
    Again, for any questions or to order, shoot us a PM through AZ or an email at [email protected].
    We have our ENTIRE parts inventory posted on our eBay Store--over 900 individual items from 96-01 A4s, 92-97 100s/A6s, V8 Quattros, etc.--all posted with pictures. Browse our inventory at your convenience! THANKS FOR LOOKING!!!
    A&P Auto Specialties, LLC • 1960 County Road 90, Suite 100 • Independence MN 55359
    Mar 15 2008
    A few Audis
    Independence, MN
    Re: Parting out: 2000 S4 Avant 6-speed Santorin Blue
    Pics coming within the hour...
    Jul 01 2008
    here n there
    Re: Parting out: 2001 S4 Avant 6-speed Santorin Blue
    You have a PM
    Mar 15 2008
    A few Audis
    Independence, MN
    All PM's replied!
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    I can see the side mirror glass in the pics... but don't see them on the website. I need a driver's side auto-dimming mirror. Do you have this part still???
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Established Member Two Rings sr71sss's Avatar
    Jan 20 2009
    anything with 4 wheels
    brentwood
    Interested in the pair of 2000 s4 headlight assembly prefer no broken tabs LOL
    air bag control module for a '98 audi a6 2.8
    radiator grille/latch assy w/bolts '98 a6 2.8
    Drivers side front fender a6 2.8 silver color preferred
    lower steering column dash trim, blue in color
    2000 s4 rear strut/shock assembly
    2000 s4 drivers side door speaker, does the price include the tweeter assy also? ($50 bose speaker(s) )
    zip code 94531
    Conrad Abastillas
    650-302-5127
    Antioch,California
    2001 A4 avant 2.8/wannabe S4 avant someday
    Mar 15 2008
    A few Audis
    Independence, MN
    Quote Originally Posted by lookaught View Post
    YGPM
    Senior Member Three Rings ForceFed's Avatar
    Dec 30 2008
    minnesota
    sad to see it get parted.
    damage dont look that bad
    01 Silver s4. BASIC BITCH
    04 Ultra Sport black on black 1.8t 6spd Avant
    00 s4 6spd dp's, magnaflow twin 2.25in,k04, j-fonz ,pss9's,hotchkiss sways,19vmrSOLD
    sold98 a4 1.8t quattro 5spd, some mods...GT2860elim,unitronics tune, 415cc injectors(green top), 3in vr6 maf, carbonio intake,2.5in exhaust, bilstien pss9's, 18in OZs, EVOMS intercooler 2.5in piping ect..
    sold91 ford sho white on black, modded
    Jan 05 2006
    PDX
    Sent you a PM regarding the rear binders.
    2000 A4 1.8T Avant
    APR SIII
    Veteran Member Four Rings rocky.ca's Avatar
    Aug 24 2008
    PM sent
    Mar 15 2008
    A few Audis
    Independence, MN
    Quote Originally Posted by ForceFed View Post
    Insurance totaled it out.
    But hey, on a bright note we all get to benefit from great parts!
    Sep 17 2006
    07 cbr600
    damn, poor s4 avant now there is 1 less of a rare bread in the US :(
    Veteran Member Four Rings the_pirate's Avatar
    Apr 08 2008
    Houston
    i'll take the rearview mirror! does it have working auto dim?
    History:
    2001 A4 1.8t manual swapped
    2007 GMC Sierra ext cab
    2002 Chevy Tahoe Z71
    Mar 15 2008
    A few Audis
    Independence, MN
    Quote Originally Posted by the_pirate View Post
    Sorry- the rearview mirror has sold.
    Apr 08 2008
    Houston
    Quote Originally Posted by AP-Specialties View Post
    damn.....well if you get anymore let me know
    by the way i don't know if you got my e-mail or not but that clock spring is for a manual car and i have a tip....didn't fit
    History:
    Oct 29 2005
    10speed
    San Francisco, CA
    NICE
    - Clint
    Veteran Member Four Rings Euromike's Avatar
    Oct 03 2008
    what garage?
    Pittsburgh
    Do you happend to have a santorin headlight washer cap, either off this car or another part out? Thanks
    Veteran Member Three Rings Fink_tha_Audi's Avatar
    Jun 14 2008
    99.5 Audi A4 1.8t Q
    Middletown, Delaware
    What kind of suspension is it on? Cuz it seems lowered. How much for in-dash cupholder?
    99.5 A4 1.8 TQM
    Eliminator GT2871R, UNITRONIC "440cc" tune, FMIC, 2.5" exhaust, SB Stg 4, Gutted LaBree, B&M short shifter, 034 Snub Mount, AWE DTS, LLTEK FR Strut Bar, Synapse DV, SCAT Rods, 034 HF Exhaust Manifold
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    ygpm :]
    TEAM|AXION
    Veteran Member Four Rings hoganalley's Avatar
    Feb 23 2007
    Burlington
    FACK!!!!
    I asked a week ago and you guys didn't have anything....went and bought a flat screen TV.....now I have to wait. Hopefully another one comes along soon......
    shit.
    14 A4 allroad - stock
    05 allroad 2.7T Stock
    Aug 04 2007
    92 Jetta,2001 A4 2.8
    Cranston, RI/MA
    YGPM
    ~Bo
    92 Jetta- daily-slammed,TP...to much to list
    01 2.8- project
    Veteran Member Three Rings Naudi_Mat's Avatar
    Nov 02 2007
    2008 S-Line A4
    Denver
    YGPM!
    Veteran Member Three Rings willowtreexx's Avatar
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    YGPM
    2000 A4 1.8TQ Auto tip
    Unitronics Stage 1 chip / H&R coilovers / 18x8.5 MRR GT1's/35% tint
    Sep 28 2006
    Lexington
    Headlight with everything that goes with them!! What kind are they I see the have clear corners?
    Front bumper also with fog light
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    K04 | GIAC PC-16 | FMIC | 3" Neuspeed Exhaust | ATP Test Pipe | Raceland Coilovers | N75 Race | Forge 007 | K&N | VDO Boost Gauge | A8 BBK | Rear Fog Light Mod
    07 A4 3.2LQ - K&N
    Mar 15 2008
    A few Audis
    Independence, MN
    Quote Originally Posted by hoganalley View Post
    FACK!!!!
    shit.
    Sorry, spur of the moment. We'll get another in soon!
    Quote Originally Posted by SantorianA4 View Post
    Sold with the bumper. Sorry
    Quote Originally Posted by AudiTurbo View Post
    YGPM
    Thank to everyone who has requested parts. I am trying my best to keep up with you all! Total of 136 PM's so far today!!!
    If I have missed something or have not responded, please give me a call 763 479 5333. I am trying my best to keep up!
    Aug 04 2007
    Cranston, RI/MA
    such a nice car...gotta be hawked with these S4 parts huh..daaang
    ~Bo
    01 2.8- project
    Sep 28 2006
    Lexington
    Headlights?
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
    Mar 15 2008
    A few Audis
    Independence, MN
    Headlights?
    YGPM
    Jun 29 2007
    antioch, Ca
    Will the bumper fit on a sedan?
    Mar 15 2008
    A few Audis
    Independence, MN
    Quote Originally Posted by a4natic View Post
    Yes, but the bumper is sold.
    Sorry
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    hood?? i need a hood pretty badly, mine has significant acid rain damage
    {99.5 Avant}
    Mar 15 2008
    A few Audis
    Independence, MN
    All PM's responded
    Mar 15 2008
    A few Audis
    Independence, MN
    SOLD
    so far:
    Bumper
    Cluster
    Center console
    Drivers Seat
    Fog Lights
    Climate Control
    Radio Cage
    Steering Rack
    all 4 O2 sensors
    Side Skirts
    Cargo Cover
    DS fender
    DS Door
    central lock pump
    front fender liners
    driver door handle
    driver door felt
    Sep 06 2007
    Bricktown, NJ
    Possibly interested in Headlights - please PM me
    Mar 15 2008
    A few Audis
    Independence, MN
    PM sent
    Senior Member Three Rings samtimtom's Avatar
    Sep 28 2006
    02 Audi S4 Avant
    SB, CA
    possible interest in the cowl cover...the piece that covers the battery area, not the piece that is directly next to the windshield. How much shipped to 93105?
    First Audi: 1981 5cyl coupe (non-quatro) Silver with Black Leather
    Second Audi: '02 S4 Avant Tip, Stock Everything, Baby Car Seat Mod. Silver with Black Leather
    Need a gift? Go to www.sbgiftbaskets.com
    Mar 15 2008
    A few Audis
    Independence, MN
    ygpm!
    Mar 15 2008
    A few Audis
    Independence, MN
    Plenty of parts still ready to go
    Engine
    Transmission
    passenger mirror
    pass door and fender
    BRAKES!
    carpet
    AB&C pillars
    headliner
    headlights
    HOOD
    arm rest assembly
    Rear seats
    Front passenger seat
    Bose Speakers
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    YGPM and $ for the hand brake cover...
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Mar 15 2008
    A few Audis
    Independence, MN
    Quote Originally Posted by D's Avant View Post
    Got it thanks! It will ship out today.
