Originally Posted by
JayStang
How much should it cost to have them aligned? I just installed a magnaflow 16601 system on mine and i worked for hours to get them straight w/ no luck so I'm planning on bringing it to a muffler shop to do. I heard having them weld in a spreader like the stock exhaust has helps. I'm so anal about it, i want them perfect.
If any exhaust shop just says 'we are going to heat the hanger and bend it' get your car out of there immediately!
You have to cut the old exhaust hangers off, center the tips and then reweld them on. Having a crossmember in between the mufflers helps as well.
When that is done you can also drill out some of the mount of the rubber exhaust hanger to allow for some slight adjustments and you can add some thin shims to perfectly set the tip in place.
