Results 1 to 2 of 2
Thread: Turn Signals
    Veteran Member Four Rings lude2euroa4's Avatar
    Aug 22 2005
    Jersey
    Turn Signals
    Add this to the list of issues im having with this car.
    I picked up another b5(2001) in august and the problems with it just keep on coming.
    My turn signals are having some problems when signaling left or right it blinks once or nothing at all, and the arrows in the dash freeze not lit.
    I tested the hazards since thats where i thought the issues were related, but the hazards are fine. Im assuming its electrical would it be the signal switch?
    anyone experience this?
    When moding is an art...
    Oct 06 2008
    new britain connecticut
    Re: Turn Signals
    this is a common problem what you need to do is pull the cover from the emergency flasher and make sure there is no clamps pinching any wires or connections there should be a clip on the bach of your emergency flasher that is pinching. this is caused from pressing the flasher button too hard. all you need to do is bend it back to normal and your problem is fixed. of if you take it to a dealed they mighe even fix it for free its really a simple fix.
