Results 1 to 25 of 25
    Active Member Four Rings juggernaut201's Avatar
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    Post cutsom inlet pipes
    so i know alot of us have made our own intake (inlet) pipes... lets see some pics and what you used to do so .... once i figure out how to post pics i will 2 lol [Confused]
    *JUGGERNAUT*
    (Revo Stage II + HPFP File, AWE Cat Back, DMH Performance Electric Cutout, Forge Diverter/Spacer, Carbonio Intake, AWE FMIC, Snub Mount, RS4 Motor Mounts, S4 Big Brake Kit, E Code TestPipe, KW Variant 3 Coilovers, H Sport F & R Sways, KMD Fuel Kit, KMD Cam Follower, NGK Colder Plugs, Boost Gauge, South Bend Stage 3 Clutch, ECS Light Weight Pulley,Custom Inlet Pipe, 034 Street Mount, Apikol Rear Diff Mount, JHM SS Kit W/ Linkage Upgrade And Weighted Knob Lo Jack
    276hp/331tq
    Veteran Member Four Rings Charles's Avatar
    Jacksonville
    Re: cutsom inlet pipes
    http://www.audizine.com/forum/showth...ghlight=intake
    I just did this today. Went to a local diesel truck parts store to get a 3", 90 degree mandrel bent pipe (which I plan to powder coat to make look prettier) for 18 bucks. Went to Pep Boys and found a Spectre 3" to 3" coupler and a 3" to 2.5" reducer (7 bucks each). I also picked up a universal K&N from there too (63 bucks :( ). From there, I removed the air box and started fitting things. I had to cut the pipe maybe 4 inches on each end (it helps if you own a grinder with a cutting wheel), then I just put everything together and tightened her up (don't forget to hook up the MAF in the right flow direction).
    From here I might change the filter to fit a little better. The current one is about 6 inches long, so a 5 incher might fit better. I also might add a 45 degree coupler where the MAF connects to the pipe, so I can angle the filter a little better..mostly for looks.
    As for a heat shield, I'm thinking of making a Plexi/Sheetmetal hybrid. Sheetmetal for the vertical portion, closest to the turbo (with A/C ducting insulation, painted black) and plexi for the "cover", or horizontal piece. I think it would look cool if you can see the filter. Might be cheesy..we'll see.
    For performance...pretty sure it's nil, but you can def hear the DV bleed off and the turbo whine is much more noticeable.
    Good luck! It's not that hard to do.
    2013 S4 - 200mm crank pulley (3.162 ratio), 034 Stage 2+, USP intake, MercRacing HX, Sachs XTend clutch, SS clutch line, Borla exhaust, gutted cats
    Veteran Member Four Rings NorcalPB's Avatar
    Jul 16 2008
    Supercharged M3...sold/ Titanium B7 A4
    San Francisco
    From Keith@APR
    Quote Originally Posted by Keith@APR View Post
    To answer your question I was researching the thermal conductivity of both materials, an aluminum and polymeric materials or plastics.
    My research led me to a great explanation of why metals conduct heat more freely than plastics.
    http://www.madsci.org/posts/archives...3825.Ph.r.html
    "In plastic materials, there are no free electrons, there is no real atomic order to support phonon transport or energy, so heat transfer is the slowest. In plastics molecular rotation, vibration, or movement transfers heat."
    All metals contain free electrons and have a nice and neat atomic order. This means the atoms are neatly stacked in line and/or on top of eachother and each atom shares electrons with eachother or forms an "electron cloud".
    Plastics are not stacked neatly at the atomic level and do not share electrons. This inhibits both thermal conductivity as well as electrical conductivity.
    Due to the wide variations of plastic and plastic composite materials its difficult to find the assignation of thermal conductivity to the material our oem induction systems are made of.
    Aluminum is pretty easy as a general rule: Thermal conductivity (300 K) 237 W·m−1·K−1
    Actual thermal conductivity testing would need to be accomplished to gain the exact differences between the 2 materials but I trust the explanation listed above and the research its derived through.
    So, in short, aluminum or any metal would be a poor choice for an induction system over plastics.
    Veteran Member Four Rings agkellyboy's Avatar
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    Quote Originally Posted by NorcalPB View Post
    From Keith@APR
    Why mine is coming off
    FS - Dolphin B7 A4 Ti 2.0T MT6 Quattro Project 400R
    Jacksonville
    Which is why I plan on getting my piping powder/ceramic coated.
    Still, I did mine for a few reasons:
    -replacing the stock filter with a reusable filter
    -removing the stock airbox to the filter is easier to access
    -the louder sound of the turbo and DV.
    Did I lose hp by doing this? Maybe, but it's not enough to really override the reasons stated above. Still, if this heat conduction issue was such a problem, I would think I'd notice tuners shying away from the use of metal piping in the fabrication of intakes and intercooler tubing. I don't see that happening.
    Jul 16 2008
    San Francisco
    Quote Originally Posted by Charles View Post
    I seriously doubt you did. With proper shielding the filter can run really cold (but this is rather insignificant as pre-turbo temperatures are meaningless and have no affect on the turbo's preset burning temperatures. So basically on a turbo charged car all you want is as much air flow as possible. Given the fact that an open filter allows more flow than the air box, you definitely didn't lose hp.
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    im lookin for how someone did one on a carbonio .... the bends suck lol
    *JUGGERNAUT*
    276hp/331tq
    Veteran Member Four Rings CZA420tAvant's Avatar
    May 24 2008
    06 A4 Avant 6MTQ Brilliant Red
    Orange County, NY
    ^ agreed I would like to see this also.
    Driving: 2006 Brilliant Red A4 Avant 2.0TQM
    Revo Stage 2|Carbonio Intake|Stasis SS coils|Podi Gauge|iForged 19"|H&R spacers|RS4 F/R sways|custom inlet pipe|Milltek turbo back with custom twin tips
    Endorsing:
    Dec 17 2008
    Illesheim, Germany
    Quote Originally Posted by juggernaut201 View Post
    Its not custom but it is the GSG inlet pipe....
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    i don't have a heat shield yet, but when i swapped my stock airbox back in before dropping my car off for service, the car defiitely felt peppier, and sounds ever so slightly deeper with the stock box on. granted "feeling peppier" doesn't really mean anything, it could be completely psychological.
    for those of you who want to make it fit the stock box or the carbonio, i might suggest using a 3" 45 degree silicone coupler, instead of the 3" straight silicone coupler to attach the pipe to the maf housing. it might require some test fitting, and cutting the pipe down a little more, but it'll give that extra bend that your stock rubber pipe has (actually, the stock rubber pipe is more like a short straight pipe with 2 45 degree bends at each end) a 45 degree silicone coupler will cost significantly more than the regular straight coupler. i just ordered mine last night, so it should be getting here shortly. i'll have some more info when everything comes in.
    Mar 02 2007
    Brisbane, Australia
    Lightbulb Re: cutsom inlet pipes
    CARBONIO v2.0 TEASER. DIY thread coming soon.....
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    just started a redesign of mine. i'll have some pics up in a couple of days.
    Quote Originally Posted by DownUnderSLine View Post
    i considered going this route as well. it would be a lot easier to custom fit. let us know how it goes.
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Here's the stuff.
    90 degree aluminum 3" intercooler pipe
    3" to 2.5" silicone reducer
    3" silicone coupler
    Amsoil Ea Filter part number: EaAU3051 (3" opening)
    HKS clone foam filter - 3" opening
    I cut the aluminum pipe down using the stock rubber pipe as a template, and painted it using a high temp matte paint (it can withstand 600 degrees Fahrenheit constant temperature, and spikes of up to 1200 degrees F). I wanted to powdercoat the pipe, but my hookup flaked out, and i got impatient.
    i also exchanged the 3" silicone coupler for a 3" 45 degree silicone coupler
    i've also decided to go with the amsoil filter instead of the fake hks.
    i'll try to install this tomorrow, and post some pictures of it on the car
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    sounds good i think im going to try that silicone intake pipe
    *JUGGERNAUT*
    276hp/331tq
    Jacksonville
    I'll be interested in how your setup turns out, Pink. I Was thinking of going 2, 45 degree bends, test fitting them, then welding them up (or maybe just using another 3"-3" coupling) instead of 1, 90 degree.
    I just got flashed yesterday and the tech mentioned that it might not be a good idea to have the filter so close to the MAS, as it could cause some turbulence and cause erroneous readings. He suggested, having the pipe make a u-turn so it would be:
    filter>u-turn pipe>MAS>pipe to turbo inlet.
    Thoughts?
    Jan 09 2009
    FL
    Quote Originally Posted by p1nk50ck View Post
    Here's the stuff.
    yes please..
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Thoughts?
    interesting setup, but when you place the maf so close to the turbo, i would assume that there would also be just as much turbulent air (turbo sucking in). i would also be worried about the heat given off by the turbo which may damage the maf. carbonio, evolution motorsports, AEM, GSG, and other aftermarket companies have been running the filter right off of the maf pipe, and i haven't heard of any issues (however that doesn't mean it doesn't happen)
    i do know that too much turbulent air and a sensitive maf can lead to CELs. it's a big problem with is300s. a lot of people try to retain the factory "ram air" piping (similar to our audi piping) when installing a short-ram intake. the ram air pipe would aim the cool air from the front grille directly onto the filter right behind the passenger side headlight. while a good idea in theory, this setup caused CELs. once you removed the ram air pipe, the CEL went away.
    i want to let forum readers know that i'm not an engineer. i'm just an auto enthusiast who likes to tinker with things. i try to read up on as much stuff as i can, and gain an understanding of mechanics to the best of my abilities. if anyone has any further insight, please feel free to chime in or correct me if i'm wrong.
    Quote Originally Posted by Hyphy View Post
    yes please..
    i'm at work right now, and i didn't expect it to snow today. i don't have a garage, so i'll have to try and install it on my way out of the office. it shouldn't take more than a couple of minutes, but i'm in a suit, and i'm too much of a pansy to let my suit get ruined just to install an intake pipe. i'll see what i can do.
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    so whos gonna make a diy on the silicone pipe? :)
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    if he doesnt i will .... i cant wait my stuffs in the mail i did one thing dif tho i went 3 inch 45 degree coupler and then the 3 to 2.5 90 degree
    *JUGGERNAUT*
    276hp/331tq
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    he inlet pipe i made previously just isnt doing it for me
    *JUGGERNAUT*
    276hp/331tq
    Mar 02 2007
    Brisbane, Australia
    Quote Originally Posted by RedS-line View Post
    Have been very busy with work this week - will do a quick DIY on it tomorrow night.... unless Juggernaut beats me to it !
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    haha my parts arnt here yet haha so the floor is all yours lol
    *JUGGERNAUT*
    276hp/331tq
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    is today the day for the DIY? lol my parts are in but i wont have time to make it fit till 2morro nite lol
    *JUGGERNAUT*
    276hp/331tq
    Jul 21 2004
    South Florida
    Temps of air brought in through the MAF do have an impact on intake air temps taken at the manifold post turbo and intercoolers. Proof of this is taking simple intake g/s readings on a 50 degree day versus on an 80 degree day.
    cheers! Mike
    2018 Audi S5
    Gone-
    Mar 02 2007
    Brisbane, Australia
    YES.....YES IT IS....
    http://www.audizine.com/forum/showthread.php?t=261082
