Results 1 to 4 of 4
Thread: COOLANT !
    Established Member Two Rings miamiboy305's Avatar
    Nov 29 2006
    '03 A4TQM
    West Texas
    COOLANT !
    ok so idk wuts up wit my car now the coolant light had been turning on so i checked the coolant aand it was completely gone so i bought the pink coolant from factory ion ecs tuning and i filled it up. it went all the way to like halfway between max and min. now 2 weeks later its almost all gone again and the stupid light is coming on again. do u think its a leak or is it that it just wasnt enough.
    '03 A4TQM
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Re: COOLANT !
    Could be a few things.
    Blow gasket
    and double and tripple check for leaks under the hood. Check the rear flange close to the firewall and see if that is leaking.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Veteran Member Four Rings eurogruppe's Avatar
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    Re: COOLANT !
    check the bleeder cap on the rail under neath your engine cover and look for signs of coolant leaks
    21' Audi RS6 | E30 M3 | 996 Turbo | Corrado SLC | IG: @stevedavid993
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    Re: COOLANT !
    Most likely not a blow head gasket, if that was the case you would have alot of white smoke out of the tail pipe.
    My guess' are rear coolant flange, or something along those lines where its leaking, look for pink crust as "eurogruppe" says.
