Thread: controll arms
    Senior Member Two Rings Greg9's Avatar
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    controll arms
    Has anybody put controll arms from a B5 A4 or B5 S4 on a B6 A4 with sport suspension?
    The set Im looking at say they are compatable with......
    Audi A4 1.8, 2.8 1996-2001
    Audi A4 Quattro 1.8, 2.8 1996-2001
    Audi A6 2.7, 3.0, 4.2 1998-2002 with 15” or 16” rims
    Audi A6 Quattro 2.7, 3.0, 4.2 1998-2002 with 15” or 16” rims
    Audi S4 2000-2002 only after production date 11/1999
    Volkswagen Passat 1.8 Liter and 2.8 Liter 1998-6/2002
    "DRIVE FAST & TAKE CHANCES"
    White B7 A4 w/ Titanium package, APR Stage 1, APR downpipe w/ High flow cat!, NGK Iridiums, ECS Underdrive Pulley, Stoptech rotors & pads w/ ECS stainless steel lines, Meyle HD Front Control Arm Kit & rear sway bar links, Bilstein B8 Shocks, 034 Motorsport 25mm rear swaybar, 034 Motorsports Street Motor Mounts, ECS Snub Mount, ECS Rear Differential Carrier Mount Bushings Insert Kit, Forge Atmospheric BlowOff Valve, ECS Throttle Body Hose, AEM air filter kit.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: controll arms
    Upper or lower?
    -Doug
    Buncha motorcycles
    Memphis, TN
    Re: controll arms
    ela filo! why dont you want b6 CAs?
    APR Stage 2/AWE Intake
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: controll arms
    Quote Originally Posted by Papachristou View Post
    He probably found a deal on the ones he specified. I just don't know if he wants upper or lower. I think the lowers are the same but the uppers might be different. I gotta go look at ETKA tonight to see.
    -Doug
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    Re: controll arms
    Exactly I found a good deal on a set that are said to be for the cars I listed. Mine are getting kinda bad. haha lets put it this way the last autocross event I went to there was a tight highspeed slalom and I kept leting off because i thought I herd me hitting the cones but in the rear view everthing was ok. It took me a few passes to figure out it was the control arms or a tie rod.
