Results 1 to 7 of 7
Thread: Starting Issues
    Veteran Member Three Rings Tallbino's Avatar
    Sep 09 2004
    B5 S4
    Fort Worth, TX
    Starting Issues
    Hey guys, so i started my car last friday, and after idling very roughly for about 10 feet it died. I got it started a couple more times but it would die almost immediately. I tried starting it a few more times, but a chime would come on, and the oil light would come on. My battery is fine, and i even got jumped to make sure that it wasn't my battery. The only codes i got were misfires.
    Anybody have any ideas? Mods are in my sig, I recently changed my oil with Royal Purple 5w30 and the level is fine. I also changed my plugs with BKR7E's. I've never had this issue before in the 4 years I've owned this car.
    Bucknell University '10
    '11 Alpine White/Coral Red BMW 135i - Stock
    '01 Silver, Black/Silver Alcantara S4
    Vast St 3 Tune, AWE fueling, AWE DP's, AWE SMIC's, AWE st 2 clutch/lwfw, Bosch 044, JHM Solid SS, DBA 4000 slotted rotors, PBR Ceramics, APR SRT Cat-back, 034 snub w/bracket, RS4 mm, 32% tint, AWE Boost gauge, M3 lip spoiler, AWE DTS, SR Vogtland GT's, H-Sport Sways, Low temp thermoswitch, Greddy TT, Fan delete, Alpine CDA-9855 & Ipod hookup, JL 12w3v2 & JL 250.1, AWE Pedals
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    Re: Starting Issues
    It is very difficult to diagnose without codes. Did you mess with the ignition modules at all? Check and make sure all of your coilpacks are seated properly on the plugs. Make sure you don't have any MAJOR vacuum leaks. Let us know.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Sep 09 2004
    B5 S4
    Fort Worth, TX
    Re: Starting Issues
    Hm, i will check the ignition modules. I had to take them off to replace my air filter, and i scrubbed off what i thought was corrosion. Im guessing that's some sort of contact promoter. any idea what i should put on it? I know i don't have any huge vacuum leaks.
    Sep 09 2004
    B5 S4
    Fort Worth, TX
    Re: Starting Issues
    tried starting the car again yesterday with no success. I realized that I can no longer hear my fuel pump. Pretty sure it's dead. I talked to my mechanic, and he said that with my symptoms a bad fuel pump sounds about right. I just ordered a bosch 044 from 034. Hopefully that fixes the problem. I will keep you guys posted.
    Sep 09 2004
    B5 S4
    Fort Worth, TX
    Re: Starting Issues
    Hey guys, just figured that I would update with the solution. It was a combination of a plugged fuel filter, bad connection on my icm's, and fouled plugs from all the cranking.
    Veteran Member Three Rings audikidS4's Avatar
    Sep 03 2008
    2001.5 S4 Avant 6spd - Sil/Blk, 1995 S6 Avant - Blk/Ercu
    Wareham, MA 02571
    Re: Starting Issues
    Quote Originally Posted by Tallbino View Post
    Thanks for updating your thread with the fix. This is very important so when I get similar trouble, I can read what fixed your problem. I wish everybody did this...
    The original audikid! Coined as ebay username spring 1999.
    **MTM ECU, Piggies, ASP Tru-Duel, Stratmo ss kit, Stern sm, AWE DTS, Voltgland GT2, Neuspeed 19mm RSB, full Samco kit, drilled and slotted rotors, PODI/S-W boost gauge, Sportec pedals, 30% Huper optik, CCMod, stubby antenna, VMR 708s 18X8.5 32mm**
    Sep 09 2004
    B5 S4
    Fort Worth, TX
    Re: Starting Issues
    No problem man. Probably would have saved me a few bucks if everyone did this!
