Results 1 to 15 of 15
Thread: cel
    Veteran Member Four Rings italian a4 1032's Avatar
    Oct 17 2007
    mass
    cel
    on the way home from school a cel with check under it came on/ mil malfunction indicator light
    i looked it up and it has something to do with the engine electronic system
    i have 35400 miles and it also says it needs to be serviced in 100 miles does that have anything to do with it? and do i need to service it if i got an oil change at like 33000?
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    Re: cel
    Quote Originally Posted by italainboy1032 View Post
    Oil changes every 3-4K man. Do that, some plugs, maybe a fuel filter and call it a day (I'm due for that service pretty soon).
    Did you actually check your codes and get a number or anything?
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
    Oct 17 2007
    mass
    Re: cel
    Quote Originally Posted by Exanimas View Post
    i dont have a vag
    Buncha motorcycles
    Memphis, TN
    Re: cel
    autozone will tell you code for free
    APR Stage 2/AWE Intake
    Veteran Member Three Rings dextrek's Avatar
    Aug 26 2008
    B7 S4
    Detroit
    Re: cel
    Your ecu cover is prolly leaking. Try to tighten both inner and outer shell. This happened to me as well as my friend. He told me about this issue and it has been fixed since I tightened...but yea, see what the code is for...I never checked mine and I want to know.
    -Ben-
    B7 S4 Dolphine Grey
    B6 A4 USP Moro Blue *Sold*
    Oct 17 2007
    mass
    Re: cel
    ok i went to autozone and got the code P0441 the guy there said it might be something with the purge valve and then I went to the stealership and they couldnt tell me whats wrong with it unless I bring my car in and didnt know if its covered under warranty or not
    any idea whats wrong?
    Oct 17 2007
    mass
    Re: cel
    bump
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    Re: cel
    that is an evap leak code... you may have not tightened you gas cap all the way.. or have a bad gas cap.. or actually have a leak (not common) probably gas cap
    Oct 17 2007
    mass
    Re: cel
    ok so i brought the car to audi today and they said there were 2 coolant leaks which will be covered under my warranty and theres also something wrong with the freeze plug I guess its something to do with engine block and they want almost $300 for it plus 100 for the warranty deductible, do you think thats too much for the freeze plug?
    Oct 17 2007
    mass
    Re: cel
    yayyyyy i have this cel again
    b6 a4-sold
    2013 m3
    Senior Member Three Rings JeffM03's Avatar
    Dec 30 2009
    Waterbury, VT
    Re: cel
    Is it the same code? Just saying you have a CEL doesn't really tell us much...
    Aug 14 2007
    2002 Dodge Dakoto 4.7L & a 1990 Honda Accord that won't die
    Bellevue, WA
    Re: cel
    Quote Originally Posted by italian a4 1032 View Post
    Why are the two other coolant leaks covered under warranty and not the freeze plug? Dealer should fix that also under warranty.
    There's a technical service bulletin (TSB) out on that freeze plug. Yes, $300 is too much for that work IMO, but probably the same price at any dealership. If you have mechanical ability and the desire to work on your car and DIY, here's how to replace that freeze plug yourself -- link to post which includes TSB link.
    Veteran Member Three Rings hbodo08's Avatar
    Apr 06 2009
    04' a4 3.0 ** 02' envoy slt--85' iroc z 28 (7400 original miles) 2010 Mercedes e350 4 matic
    The ville, Ohio Akron, Ohio
    Re: cel
    Quote Originally Posted by dextrek View Post
    yep thats what mine did it had a crack in it and was messing the ecu up.. every time i washed my car and drove in rain... but i got a new cover at the dealer for 35 and replaced it and no problems
    I drive it like i stole it , then again
    /____________________\
    [_oo_\===0000===/_oo_]
    \_o___[HMB-30A4Q]___o_/
    Oct 17 2007
    mass
    Re: cel
    Quote Originally Posted by JeffM03 View Post
    yes same code which sucks because ive been trying to sell this car so i dont drive it anymore but my other car broke 2 weeks ago and my parents havent had it fixed yet becuase its been too cold for my neighbor to look at it
    b6 a4-sold
    2013 m3
    Dec 30 2009
    Waterbury, VT
    Re: cel
    Well, an easy fix would be to replace the gas cap. A more advanced fix would be to replace the EVAP canister.
