Results 1 to 8 of 8
    Oct 03 2008
    93 White NX2000, 2005.5 B7
    Lancaster, PA
    bulb out warning every now and then
    When I bought my audi, it had a burned out DRL holder on the passenger side. I guess the original owner might have put aftermarket lights in that weren't good for it. I've since replaced the holders on both sides (The holder is Black instead of white) and I still get the bulb out warning every now and then. If I get it...I just turn off the car and restart it again to have it go away. It's not a problem, but very annoying. I was wondering if anybody has had this problem and if there is a solution to this. Do I have to reset the ecu some how? I'm chipped by the way.
    Joshua
    Veteran Member Three Rings Latin Audi's Avatar
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Re: bulb out warning every now and then
    You get a dipped headlight warning? If so tons have this problem, just do a search. Most likely ballast.
    Brilliant Red 2005.5 A4 2.0T Quattro 6MT
    APR 93 | Evoms CAI | RS4 Sway | CC | De-Badge | ECS Snub Mount | 5%| Ziza City Lights
    Oct 03 2008
    Lancaster, PA
    yeah...I've read about that. But that has only happened to me once. I'm talking about the bulb out warning when i start the car. It's definitely associated with the DRL. Not sure why it only happens sometimes though...not all the time.
    Joshua
    Veteran Member Four Rings chaze's Avatar
    Sep 16 2007
    2001 A4 Avant, 2009 328i
    Canyon Hills, CA
    Quote Originally Posted by NothingBUTasian View Post
    Joshua
    So it only happens when you start it? Just today I got a plate lamp warning after hitting a nice hump on the freeway, and then it went away. Only seen that once since I installed the ultra bright bulbs back there. Gotta be a loose connection that I need to check out. Good luck man.
    -Chris
    2001 A4 Avant - Apr '11 to Present
    2008 A4 Sedan - In the graveyard
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    I get a left fog light out indicator (at least I think it's the fog light) very rarely. It happens when I'm driving usually after at least 15 minutes or so. The warning turns off when I restart the car. I have always attributed it to me messing with my headlight controls so that I can have only the city lights on with my fog lights.
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Oct 03 2008
    Lancaster, PA
    Yup...this only happens when I start the car. It never happens while I'm driving. I do sometimes get an airbag warning while driving but that sometimes goes away by itself and def goes away when I turn off the car. Is this worth taking to the dealer to look at? It's quite an annoying thing. I hate it when my car is not at it's best.
    Joshua
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    the exact same thing is happeneding to me although it's because one of my ziza led's are broken. i guess they don't have any in stock yet to replace it so till then i found a fix. i leave my lights on manual setting and after my car starts, i turn on the lights. never a bulb out warning that way. it's not a permanent fix to your solution, but it's better than turning your car on, off, then on again.
    Dec 27 2005
    Ft lauderdale
    whoops just realized you were talking about drls and i'm talking about city lights. nvmd. what about just leaving the drl's off? would that work?
