Results 1 to 20 of 20
    Established Member Two Rings Talon Load's Avatar
    Jun 23 2008
    '05 M3 Vert, '10 VW TDI Cup, '11 Grand Cherokee
    NC
    Strong fuel smell
    So my poor car had to sit out in the freezing weather the last couple of days. We got snow here a couple of days ago. So yesterday and last night my S had to sit outside in the freezing (20s) temps. When I started it up around noon I first got freaked with the white smoke which turned out to be moisture in the exhaust. I let her warm up well, didn't diver here hard home and put her back to bed. I walked out 30 minutes ago to get something out of the car and the whole garage smells like fuel. I looked under the car and everywhere I can think of and not signs of a leak. The only think I can find is that the right side top of the engine smells like fuel. I can't see any fuel leaks and no oily liquids anywhere. What could be leaking that could cause that? Anyone ever have this happen? Any info would be great.
    Senior Member Three Rings gaspeedracer's Avatar
    Jun 02 2007
    2001 Imola Yellow S4
    Daytona Beach, FL/Conyers, GA
    Re: Strong fuel smell
    did you check inside the engine bay? maybe something popped out after being frozen over.
    "A true leader has the confidence to stand alone, the courage to make tough decisions, and the compassion to listen to the needs of others. He does not set out to be a leader, but becomes one by the equality of his actions and the integrity of his intent."
    -Douglas McArthur
    Semper Fi!!!
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Leaky injectors? Theres another post on here and the guy had the same problem. Search a little and see what you can find out
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    i cracked the main fuel supply hose under the hood one cold winter morning. it's one of the three hoses that are attached to the top of the factory airbox. Start your car and look for leaking/dripping fuel
    My car is fast
    Jun 23 2008
    NC
    Thanks for all the inputs. I started the car back up after looking at everything and the smell didn't come back. I am going to take a look at the main fuel supply line. Not sure what this is all about. This is exactly why my car belongs in the garage at night.
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    There was a guy on here that had worn o-rings on the injectors from cold weather a while back. You mentioned cold weather so that might be somthing to think about. Injectors are pretty easy to check anyways.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Established Member Two Rings Krzano's Avatar
    May 04 2008
    B5 S4 stage II
    Chicago, IL
    I also had a problem with the main fuel supply hose. It runs right over the passenger valve cover from the firewall. Cost is about $60 from dealer.
    Veteran Member Three Rings lsc2g's Avatar
    Jan 07 2006
    S3%2C%20Q8
    Calgary, Alberta, CANADA
    that was me with the leaky injectors.. happened when the car was outside in -20C and below.. leaked like crazy then stopped once it warmed up
    i got 6 new injectors from the dealer and the install was like 25 minutes.. really easy
    hasn't leaked since but it warmed up here lately so it's hard to tell but i'm pretty sure i'm in the clear
    www.eurodrivers.ca
    Calgary Canada Euro Club
    Jun 23 2008
    NC
    I searched the hell out of my engine and couldn't find anything. The weirdest thing is that it hasn't happened again since. I drove it to work today, nothing. The injectors seem to be dry, at least I don't see any leaks. Hopefully it was just a fluke since she had to sit out that one night.
    Active Member Two Rings a4justen's Avatar
    Aug 27 2007
    98 audi a4 quatro, 97 gmc
    utah
    Leaking fuel injectors. it only happens when it is real cold outside. at least below 20. see it all the time in the winter.
    i fix it good!
    Jul 21 2005
    Bedford/MA
    also keep in mind that the fuel systems dumps a hella lot of fuel into the cylinders for cold starts
    My car is fast
    Jun 23 2008
    NC
    I just wonder if I didn't have small leak injector leak. The whole garage smelled like fuel, but the again as soon as you get a small amount of fuel in a confined space it's noticable fast. Happens on our planes all the time. The temps over night where well bellow the 20s and it was right around 24 when I got home. Thank goodness we don't get that kid of weather here very much.
    Jan 07 2006
    S3%2C%20Q8
    well it got cold here today and one of mine leaked a little bit
    all with new orings.. stupid god damn car
    i've never had this issue with my old mk4 jetta
    i'm gong to double check the fuel rail bolts one may need some tightening
    www.eurodrivers.ca
    Veteran Member Four Rings mrpeterparker's Avatar
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    had a similar problem today... had to tighten this nut ... it's off the main fuel line .. to the left of the y-pipe.. it was leaking fuel in drips.. FAST......
    Lurker
    Jun 23 2008
    NC
    Sweet, thanks. I'll take a look at it.
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    Thats the spot, but mine was leaking from the hose crimp not being tight enough. I thought it was the flare fitting not seating and tried to tighten it, but it never would work. The more I looked at it I could tell the crimp was weak and would leak only during very cold temps.
    I removed the whole line, cut the crimp with a cutoff wheel and used fuel injection hose clamps on the fitting in place of the crimp. Underneath the crimp pushed into the hose is a barb type fitting so the clamp works perfect. Cost like $5 for everything and a little time. Never had a problem since.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    hold on .. go slow.. cause mine started leaking again...
    you took the whole line off? and cut it? how'd you reattach the screwing nut head//// i doubt that's the right term.. but the larger nut...
    Lurker
    Apr 20 2005
    New Hartford, IA
    I removed the hose at both ends so I could clean it after cutting the crimp off. Under the crimp is hose, under the hose is a barb type fitting. Basically you replace the hose crimp with a fuel injection hose clamp. If your not good with fittings and what not just buy a new hose as they are not that expensive.
    02' Tundra
    Jun 09 2009
    Nebraska
    im having the same problem, what is the part # for that main fuel line?
    Veteran Member Three Rings Avant Fetish's Avatar
    Nov 13 2008
    Mk7 GTI / 8P A3
    So Cal
    Quote Originally Posted by mrpeterparker View Post
    Mine was leaking in the exact same spot.
    I used a worm drive clamp where the fitting meets the hose. Its supposed to be a temporary fix...but its held for over 10k.
    Cup | Corrado | Cervelo S2 | Banshee Spitfire | Evil Following
