Results 1 to 18 of 18
    Veteran Member Four Rings todd1010's Avatar
    Jun 17 2004
    Jacksonville, Florida
    Stock lug bolt replacement-any choices for lightweight ones?
    I'm more curious than anything but I'm changing out my rims today and after having a hell of a time trying to locate some locally I'm ending up with some pretty crappy chrome ones that even though are new have already started to rust in some areas.
    I've had similar chrome lug bolts before and know that that do that and it gets worse over time. So it comes to this post looking for some better looking log bolts and it would also be nice to find some that are lighter weight also. My buddy has a 1985 Porsche that he's rebuilding and it comes with some incredibly light weight lug nuts that are made of some kind of material. I don't know if they are titanium or plastic bit they weigh next to nothin.
    Jacksonville's Premier Paintless Dent Removal
    Got A Ding? Give Us A Ring!
    904.705.DING (3464)
    http://www.dent-technique.net
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Re: Stock lug bolt replacement-any choices for lightweight ones?
    www.purems.com
    Give them a call.
    ..and why did you make 2 posts asking nearly the same question?
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    I can make more weight reduction by taking a crap.
    Are you doing any other weight reduction or is this it?
    |^^^^^^^^^^^\||____
    | The STFU Truck |||""'|""\__
    | _____________ l||__|__|_|
    Senior Member Four Rings Bravest NY S4's Avatar
    Jan 18 2009
    BKNY
    Quote Originally Posted by todd1010 View Post
    Not sure about the weight of the lug-bolts, but I don't think I'm feelin chrome on an Audi holmes
    I'LL BE BACK.........
    Never forget SWAY
    Jun 17 2004
    Quote Originally Posted by Bravest NY S4 View Post
    Bravest NY, How do you like the "Tyrol sport brake caliper stiffening kit"? Can you tell me more about it?
    904.705.DING (3464)
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    2nd!
    04' Nogaro S4 - 19" BBS RS-GTs - H&R Coilovers - Hotchkis RS4 Sways - 4500k HID fogs - JHM solid shifter trio -JHM intake manifold - JHM port matched intake spacers - JHM longtube headers - JHM tune - Fast Intentions resonated catback - Snub mount - Vag mods - hardwired V1 - Clutchmaster Stage 3 clutch & 13.5 lb flywheel - Euro B7 RS4 steering wheel - Cayenne Big Reds - stern engine mounts - Stern upper control arms - K&N panel -
    Jan 18 2009
    BKNY
    Randomly found it while looking for a tuning shop out here...
    I hooked em up with some goodridge lines and noticed a considerable difference compared to that of the stock rubber slop. Its not a Brembo set-up, but it's an in expensive little mod, while keeping the S stealth!
    chiggidy check it....
    http://www.tyrolsport.com/index.php?...124&parent=165
    Never forget SWAY
    Senior Member Two Rings mystro's Avatar
    Apr 29 2005
    Woolrich Pa.
    "I can make more weight reduction by taking a crap." That must be one big fudge dragon :)
    Dec 05 2006
    So. Cal.
    That actually looks like a good product.
    Nov 19 2008
    San Jose, CA
    I have a set to install on the S4. They replace the rubber caliper bushings with bronze bushings, the idea is that they eliminate the rubber bushing's "play" and give better pedal feel when braking.
    I have not used them before, but TT and Passat owners report that they are a maintenance item (clean and relube 2 times/year or so) as the bushings are now exposed to dirt/water/road salt, which was not the case with the rubber ones.
    Senior Member Two Rings EnjoyIncs's Avatar
    Oct 24 2006
    '04 S4 DG
    Worc MA
    Quote Originally Posted by ClarkSJ View Post
    I have a set to install on the S4. They replace the rubber caliper bushings with bronze bushings, the idea is that the eliminate the rubber bushing's "play" and give better pedal feel when braking.
    Could you post a review when you get them installed?
    Senior Member Four Rings ...Mark...'s Avatar
    Oct 03 2008
    Murdered out 04 S4..
    Atlanta BITCHES!!!
    F-That.. Just get the braided lines and call it a day..
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Those are titanium lug nuts that are on the Porsche. My friend has them too and they are sweet.
    Skip lug bolts and do a stud conversion instead. Then you can pick up a set of those titanium nuts and be happy.
    I hated the fact the chrome bolts that came with my wheels started to flake and rust.
    Jun 17 2004
    Quote Originally Posted by [email protected] View Post
    Did you do a stud conversion? If so, where did you get everything?
    904.705.DING (3464)
    Jun 11 2005
    Vancouver, BC
    I did do a stud conversion and I love it. So much easier to swap wheel when you are a wheel whore like myself.
    I got all the parts from www.bildon.com but I am sure most of the other advertisers here can hook you up as well.
    Nov 19 2008
    San Jose, CA
    X2. I converted my TT to studs to use with spacers, and got the kit from Bildon.
    FYI, be sure you know if your wheels require ball or tapered (cone) seat lug nuts. Audi stock are ball seat, most (but not all) aftermarket wheels are cone seat.
    Nov 28 2007
    Massachusetts
    light weight lug nuts? take a piss before getting into your car.... should do the trick
    Veteran Member Four Rings drew's Avatar
    Jul 27 2004
    E60 M5 Gone: 996TT stage 3, E46 M3, B6 S4
    Orange County
    Quote Originally Posted by ginkof View Post
    lol.
    i have heard of titanium lug nuts but they are insanely expensive.
