Results 1 to 15 of 15
    Senior Member Three Rings eurotecknik's Avatar
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Chocolate MILKY Oil (PIC included)
    Hi all, checked oil level this morning on my 1.8T AWM and to my surprise (look at PIC) I saw this color. Milky way style oil specially designed for our cars FREE of charge . Car has 84K on the clock running 20 PSI of boost on GTRS. What are your initial thoughts? I know I know....oil cooler or head gasket most likely the first one cuz compression is good on all 4 cylinders. Coolant color is ok so I guess coolant is mixing with oil cuz of oil cooler failure. And oil is thick as hell. Now I don't have a car for the next couple of days coming from 20 pounds of boost to the BUS. Hate it or Love it all the way.
    Just drained the oil:
    01 A4 1.8T Quattro Manual - SOLD
    90 Audi 90 Quattro Manual - SOLD
    03 A4 1.8T Quattro Manual - SOLD
    B5 S4 Daily Driver - SOLD
    Current:
    06 A4 Quattro Auto
    Feb 27 2005
    North Wales, PA
    Re: Chocolate MILKY Oil (PIC included)
    if the compression is good then replace the oil cooler. Its pretty cheap so go ahead and try that first. how does the coolant look? or did it all drain?
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Haven't drained the coolant yet but looking at the coolant extension tank it is ok and level is down a little.
    Current:
    06 A4 Quattro Auto
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    BTW I searched and read all the related threads. I didn't find any pics so I thought this could be of help for someone.
    Current:
    06 A4 Quattro Auto
    Senior Member Three Rings osag52's Avatar
    Jan 06 2009
    09 Q7, HD Deluxe, 08 A4
    Miami (305)
    Quote Originally Posted by eurotecknik View Post
    looks like a long night of nachos and beer
    try changing the oil cooler as said above
    08 A4/Ibis White/SLine/TI Wheels/APR Tuned/APR Catback/Carbonio Intake/LED Int/LED Plate Lights/H&R Sport Springs/Cupra Splitter/Gutted OEM Cat (sounds great)/Podi Gauge/DEBADGED
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Oil cooler is cake. Mine is off right now because the gasket blew and oil was everywhere.
    It should take you like an hour and a half MAX!
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Quote Originally Posted by ILoveT View Post
    I am going to remove it right now so it is ready when the new one comes. List of tools needed?
    Current:
    06 A4 Quattro Auto
    Senior Member Three Rings erode's Avatar
    Nov 07 2008
    05.5 B7 S4, 98 E36 M3, 03 E46 330xi
    MN
    1) check oil
    2) discover oompa loompa factory inside engine.
    3) ???
    4) profit
    Jul 03 2008
    A4
    I would suggest flushing out the coolant system too if your oil and coolant were mixing. Also some liquid dishsoap is good for removing all the oil film from your coolant system.
    just run the car with a garden hose in the tank and a coolant line off. It took me 1 hr of flushing to get the coolant to not have a oil film on the top of it.
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Well you're gonna need to get your oil filter off.
    Take the hoses off going to the cooler. It is easier to take them off with it on. Then there is a large nut holding the actual cooler on. It should be a little more than finger tight. I didn't have the correct socket so I just used a screw driver to turn it. I think it is around a 22 or 23 millimeter. Then pull the oil cooler off. I just did this yesterday. Good luck.
    Feb 27 2005
    North Wales, PA
    yeah its a big guy. Its the biggest socket i had in my 1/2in drive metric set. I'll let you know when i get home. Just run some cheap oil for a few miles and a cheap oil filter. Then do another oil change. To flush out the coolant system, just run distilled water through it. make sure you run the engine up to temp to open up the thermostat. Then drain. If it comes out pretty clear then just go ahead and fill with the pink stuff.
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Just took off the oil cooler. It was 25 millimeter. I'd rate the job at 2 out of 10. Just waiting for new cooler from germanautoparts.
    Current:
    06 A4 Quattro Auto
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    i think ive used a deep-well 24mm for both that nut, and the oil pressure switch iirc. 25mm or 15/16" will also work, albeit slightly loose.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    condensation in the oil. coolant problems possibly
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Quote Originally Posted by B5A4Kevin View Post
    Do I have to do anything with that oil pressure switch?? I thought the procedure is as follows: Drain oil, Drain coolant, remove oil filter, remove coolant hoses going to the cooler, remove that nut, put new seal, install new oil cooler, install that nut back, install filter, fill everything back and drive happily ever after. Am I missing something?
    Current:
    06 A4 Quattro Auto
