Results 1 to 15 of 15
    Senior Member Four Rings Bravest NY S4's Avatar
    Jan 18 2009
    BKNY
    Clunkining noise on the front right side...
    Any ides on what a "clunking" noise may be on the front right-side?...it comes and goes.
    The wheel actually sounds like it's rubbing when fully turning... Control arms? CV? axle assembly? hub? bearing? Anybody??
    I'LL BE BACK.........
    Never forget SWAY
    Re: Clunkining noise on the front right side...
    Quote Originally Posted by Bravest NY S4 View Post
    I would first say a control arm is your hearing a "clunking."
    Could also be your sway bar end bolts need to be tightened.
    Did you install your suspension yourself? About the rubbing, how low are you?
    Jan 18 2009
    BKNY
    The original owner had the suspn installed, not sure where though... I'd say the car is was lowered about 2' I haven't measured it yet.
    Are those sway bar bolts, readily accessible from under the lift?
    Never forget SWAY
    Yes, its right under the rotor. Should be like a 16 or18mm bolt. Just make sure its tight. I would first check your control arms though, most common when you hear clunking.
    How many miles are on the car?
    Jan 18 2009
    BKNY
    little over 75k...
    Never forget SWAY
    little over 75k...
    Definitely check the control arms. Hopefully this helps.
    Jan 18 2009
    BKNY
    Thanks Bro!
    Never forget SWAY
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    didn't know we could drop our cars 2 feet! i keeed i keeed! g'luck!
    04' Nogaro S4 - 19" BBS RS-GTs - H&R Coilovers - Hotchkis RS4 Sways - 4500k HID fogs - JHM solid shifter trio -JHM intake manifold - JHM port matched intake spacers - JHM longtube headers - JHM tune - Fast Intentions resonated catback - Snub mount - Vag mods - hardwired V1 - Clutchmaster Stage 3 clutch & 13.5 lb flywheel - Euro B7 RS4 steering wheel - Cayenne Big Reds - stern engine mounts - Stern upper control arms - K&N panel -
    Oct 15 2008
    07 RS4
    New York
    Sounds like the control arm bushings....
    Quote Originally Posted by Hotazlava32 View Post
    Yep... Check this out
    TSB
    Jan 18 2009
    BKNY
    Quote Originally Posted by ginkof View Post
    LOL....why u trying to play me??...u know I meant inches.
    Never forget SWAY
    Jan 18 2009
    BKNY
    So we put the S on the lift, and it was the f*#@! shock....DAMN!
    Now I GOTTA get 2 NEW front coil overs..... cause I definitely cant have a mismatched new/used front coilover set-up...
    Never forget SWAY
    Veteran Member Four Rings serumk's Avatar
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    Oh boy...
    Ouch, sorry to hear about that. Any chance they are still in warranty? I believe its a 1 year period, but not sure if warranty is transferable.
    Jan 18 2009
    BKNY
    Quote Originally Posted by joeycuccaro View Post
    Dude I bought the S from had them installed before I owned it, so I'm not sure how long they've been on, and I dfntly don't know about the wrnty.... It's all good tho, I'ma bite the bullet and just get the new front coilovers, get a OEM upper-cntrl kit,Lemforder tie rod ends and start fresh....but be broke
    Never forget SWAY
