Results 1 to 11 of 11
    Senior Member Two Rings xmoox's Avatar
    Aug 12 2008
    2000 audi s4
    Portland OR
    Yayayayayayaya......broken
    So my car has been running great and has been alot of fun until tonight on the "midnight run". Im pulling out of my house taking it easy and then take a right turn hit a small bump and than BAM!!!!! cars still running and still rolling just slowing down. I shift gears to try and speed up but nothing. I can change the gears with the engine on and it doesn't matter if the clutch is pushed in or not. Car will not move at all but it runs.
    So this is what i think happened.
    Crank to the flywheel is broken.
    Clutch is stuck open
    thats my ideas Im in Corvallis so if anyone knows of a good place to go let me know.
    Any ideas on what that problem is.
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Re: Yayayayayayaya......broken
    Pressure plate not fully disengaging is a common problem. Happened to me in April.
    2000 s4
    Fairfield, CT
    dual mass flywheel went bad
    i heart my s4
    Aug 12 2008
    2000 audi s4
    Portland OR
    so you guys don't think its a clutch? and which shop should i go here in Corvallis i would take it to matrix but that too far away i have AAA so i can tow it to a shop for free. I was thinking Aamco but im not sure. Maybe ill try the little guy Ive had some good luck with them but Ive heard horror stories from other people
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    One of my axles came loose and that's what happened, except I kept hearing a clunk.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Aug 12 2008
    2000 audi s4
    Portland OR
    Yea that's what the guy said at Aamco is that is usually what causes that to happen. I hope that's what it is. I bet this is going to cost more that a grand
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Check ou the axels. Same thing happened to may A4 last year i raised the car up and what do you know my drivers side axle was hanging. All the bolts were missing, i got new bolts pot lock tight and today the car is still fine. If this is not the case than you are in for some fun and it will cost you more than $1000 more like close to 2k.
    Put the car in 1st gear and start the car see if it will move if nothing happent it's your dual mass flywheel for sure. If the pressure plate was bad you wouldnt be able the shift with the car on just with the car off.
    Veteran Member Four Rings DolphinV8's Avatar
    Feb 18 2004
    I would definitely take it to matrix in Portland.
    There are a few shops in Eugene, but I am not sure how experienced they are.
    auto haus
    up tuning
    edge motorsports
    Aug 12 2008
    2000 audi s4
    Portland OR
    so an quick update on my problem it turns out it was an axle that popped off the front passenger side. im glad i dont have to shell out 2200 but probably still going cost a lot.
    Jan 03 2008
    Iowa
    $150 bux if you do it yourself.
    Jan 11 2007
    Salt Lake City, Utah
    Quote Originally Posted by xmoox View Post
    This happened to me as well, crazy that it's a somewhat common problem! Mine magically popped off and all 6 bolts that hold that half-shaft to the flang were perfectly intact and nothing else was broken.
    Do it yourself, you may not even need a new axle and if you do it's $150 max-ish. With the car on the ground loosen the 17mm hex bolt in the center of your wheel. Jack the car up and take off the wheel. Take out the 17mm bolt you loosened. Put the car on jackstands and put the jack under the hub and jack the hub up to about where it would be normally with the wheel on the ground, and turn your wheels left (cause yours is the front passenger). With it in this position you can wiggle and pull the axle out of the hub and out underneath the car. Pull towards the other side of the car. This is all assuming you do infact need a new axle. Do the exact reverse to install the new axle, just remember to load the inside CV joint with grease. Also, clean the surface that you're sticking the new gasket on (I didn't and it was a HUGE pain to try to line it up when it lost it's tack. Also gasket glue helped keep it in place the second time:)). Make sure to clean the bolts and threaded holes in the flange thoroughly with parts cleaner and use some loctite or else this can happen again. You may want to replace the bolts anyways because I hear that they're one-time use stretch bolts (I reused mine though and have not had any problems.) To re-tighten the axle to flange bolts I had to have two people and lots of extensions to get at them. Make sure the bit is seated well in the bolts though.
    If you don't have to replace the axle, then all you have to do is the last part and re-bolt the axle to the flange. Either way an easy DIY and will save you at least a couple hundred!
    Need more details with pics, search then ask me if you can't find the DIY's.
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
