Just a warning for you since this seems to be something not everyone knows about. The AEB intake manifold will put your throttle body in a different position vs where your B6 manifold puts it. The AEB manifold points the TB at a downward angle(around 45 degs) while the B6 is much closer to being horizontal. Just ran into this issue this week when trying to fit a B6 ER comp kit to an AEB intake manifold that was put into Jakes Dads B6. After looking at many pics and looking at the 2 manifolds side by side I was able to figure out that the 2 manifolds just put the TB at different angles which is why the B5 and B6 cold side IC pipes for the ER kits look completely different.
So for those B6 owners that plan on throwing in a AEB intake manifold and are running a FMIC kit, expect to make changes to the cold side pipe. For those that are running ER kits, I have already talked to Fred at ER and I am going to try test fitting a B5 cold side pipe onto a B6 with a AEB intake manifold to see if it is a direct fit.
Pics showing the difference.
B5
B6
When trying to install the upper coldside pipe of the ER kit the correct way on the AEB intake manifold the tube ends up going right into the frame rail, twisting it so that it can go over the frame rail and more toward the head light then puts it so that sits at a 45 deg angle where it meets up to the lower pipe instead of butting right up against it like showin in the picture.
