I just purchased a 2003 A4 3.0 in September with about 91K on it. Ever since, it has been nothing but trouble. It started with a "check engine" code P0741 (Powertrain: Torque Converter Clutch Circuit Performance/Stuck Off). So I had the torque converter replaced.
Now the ESP light won't go away at times. I understand that wet weather can make it stay on, but when the roads are bone dry and it hasn't rained or snowed....why is it still on!? Time to get that replaced!
Ontop of that, an extremely loud winding/moaning noise when I turn the steering wheel (power steering pump to be replaced next week).
The car is coming up on 97K and I'm gettin anxious about having the timing belt and water pump replaced. The dealer says to have it done at 105K, and a lot of people on the forum say 90K......Definitely would rather have it changed before there is a problem.
What are the thoughts on the timing belt and water pump replacement? Also, how much does it usually cost (the dealer gave me the run-around when I asked). HOw imporant is replacing the ESP sensor? Can it wait until the tb/wp is done?
