Results 1 to 8 of 8
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    Ohlins 750f/900r B5 A4 opinions needed
    Hey Guys, do think this suspension setup will be too stiff for daily driving in SoCal?
    Stasis Motorsports 750lb/in front and 900lb/in rear.
    Any opinions would be appreciated.
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    Re: Ohlins 750f/900r B5 A4 opinions needed
    13 views no comments?
    Mar 11 2008
    B7RS4 & e46Ms
    I'll have 700f/1000r on my b6 in a few days and I'll let you know
    The fella I bought em from had them on his B7 and loved it (LA area).
    FRRG AZ Ring
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    Sounds good. I've heard of people running 900/1100 in LA.
    My car is a little lighter than the B6, but it would be great to hear some of your opinions of the ride once you have them installed.
    Registered Member Two Rings Jim@STaSIS's Avatar
    Sep 22 2008
    sonoma, ca
    That's gong to be pretty stiff. 600/700 is our normal street recommendation and that's really nice as a daily. It all depends on what you're trying to do with the car. If it's going to spend a lot of time on the track then these rates will work very well. If you don't like them you can always change the rates.
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by belinko View Post
    I've only got about 50 miles driven since I've put them on... (700/1k) but I must say I have zero regrets. I still need to raise the car up a bit more and do some more tweaking, but the ride is simply fantastic. I've ridden in caged 2500lb dsms and evos that feel solid as a rock over bumps... This is not like that at all... It's perfect for the street IMHO.
    FRRG AZ Ring
    In Limbo Two Rings
    Oct 07 2004
    Northern California
    Keep in mind, B5 and B6/7 chassis use very different spring rates. Try not to compare the two as the rear springs on a B6/7 car will be significantly stiffer.
    B5 a4 would be nice as a daily driver with 650fr/750rr
    B6/7 A4 would be nice with 650fr/1100rr
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    Hey guys, thanks for the input.
    I'll be giving you a call Jason. I've got some other questions and need to order a resevoir mount.
    I will be tracking the vehicle more and more as I learn how to drive the vehicle properly and as my modifications progress (i.e. brakes, clutch and diffs)
