Results 1 to 9 of 9
    Established Member Two Rings bbkid43's Avatar
    Sep 24 2006
    Minnetonka, MN
    Anyone know if these wheels will fit?
    I'm so close to buying a new set of wheels for the summer. I know the front will fit but I'm wondering about the rears. They are 18x10 with an offset of 25. Anyone have experience with this fitment?
    Veteran Member Four Rings ryannorthcott's Avatar
    Jul 10 2008
    2002 A4 1.8T Quattro
    Kelowna BC
    Re: Anyone know if these wheels will fit?
    i'm pretty sure they won't
    two thousand two audi a-four quattro five speed
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    wow, i don't think so man. You will have some CRAZY poke, about an inch to be exact. and i'm not so sure about clearing the upright either. This is just a guess, no actual experience with wheels this wide.
    Active Member Four Rings juggernaut201's Avatar
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    thats really big dude i dont think so .... id def c if you can go 2 a rim shop and find something similar and see if theyll put it on the car for you to "see if you wanna buy" nd go from there
    *JUGGERNAUT*
    (Revo Stage II + HPFP File, AWE Cat Back, DMH Performance Electric Cutout, Forge Diverter/Spacer, Carbonio Intake, AWE FMIC, Snub Mount, RS4 Motor Mounts, S4 Big Brake Kit, E Code TestPipe, KW Variant 3 Coilovers, H Sport F & R Sways, KMD Fuel Kit, KMD Cam Follower, NGK Colder Plugs, Boost Gauge, South Bend Stage 3 Clutch, ECS Light Weight Pulley,Custom Inlet Pipe, 034 Street Mount, Apikol Rear Diff Mount, JHM SS Kit W/ Linkage Upgrade And Weighted Knob Lo Jack
    276hp/331tq
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Wow, that would be HUGE. Unless you have a RS4 widebody setup
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings NorCal1.8T's Avatar
    Los Angeles, CA
    i cant see the wheels. Are they Casper?
    2018 Mercedes GLC 300
    Sep 24 2006
    Minnetonka, MN
    bump.... I'm going for poke and i would be running some 245/35 tires so they will be stretched. Im just not sure about the inner clearence...anyone else have opinions?
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Make sure you roll your fenders
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Veteran Member Three Rings willowtreexx's Avatar
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    my friend fit 19x11s on the rear
    http://www.audizine.com/forum/showthread.php?t=220257
    heres his post of it
    2000 A4 1.8TQ Auto tip
    Unitronics Stage 1 chip / H&R coilovers / 18x8.5 MRR GT1's/35% tint
