Results 1 to 40 of 59
    Senior Member Two Rings curlyfrieS4's Avatar
    Nov 19 2008
    S4 Twiny Terbs
    San Diego
    Can't unscrew oil filter WTF!!!
    I'm stuck.
    Cant unscrew filter.
    Any suggestions?
    Sold: 2000 S4 Stage II: 17' BBS RGRs. GIAC X. JHM FMIC. Piggie pipes. 710n's. RS4 clutch & flywheel. BORLA Cat Back. UUC Short Shifter. Stasis Coilovers. Need Brembo brake kit!!!!!!!
    Current: 2001 Audi S4. Stock :)
    Senior Member Three Rings jakecro's Avatar
    Feb 08 2007
    '00 S4 6MT 324K mi stock K03s
    Pittsburgh
    Re: Can't unscrew oil filter WTF!!!
    Use a filter wrench or stick a long screwdriver through it.
    -Jake
    [email protected]
    www.audidatabase.com <--feel free to contribute material
    new siggy
    710Ns|CC|VDO Vent Boost Gauge|Piggies|LW Crank Pulley|034 Snub|Hawk HPS|K&N|Continental ExtremeContact DW
    Veteran Member Three Rings mrbogangles's Avatar
    Apr 06 2008
    ;p
    phoenix az, bay area
    Quote Originally Posted by jakecro View Post
    thats what i would do
    Nov 18 2008
    2018 Passat R 1999 A4 2.7t stg 3+ 2019 Tiguan
    Chicago
    Yea jab at it with a screwdriver, who cares if you fuck it up, its done anyway. I use these oil filter tongs that get a nice grip into it, my 1.8T is a real bitch to get off sometimes but always come off with those.
    Go BIG or GO HOME!
    Nov 19 2008
    S4 Twiny Terbs
    San Diego
    Jab it?
    Like through the sides? Cus i tried stikin the screw driver but it is seriously that tight thta there is no space between the filter and the pan.
    Nov 18 2008
    Chicago
    Take a hammer and use the screwdriver as a chisel and hit the outer edge of the filter until it comes loose.
    Go BIG or GO HOME!
    Nov 19 2008
    S4 Twiny Terbs
    San Diego
    which edge. the edge closest to the pan where its screws in or end of the filter?
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    no no, just stab it like its a pigs belly, and then turn it out.. I did that though and just magled it...
    You need to get a filter wrench man, save yourself the mess.
    Nov 18 2008
    Chicago
    Whichever edge you can hit on the oil filter to get it to turn to get it off.
    Go BIG or GO HOME!
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Go to the parts store or wal-mart and buy a filter wrench. It's $10 bux and it will save you from the mess. Buy one that you think it will do the job.
    Do you have some big plyers?
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Quote Originally Posted by GetAwayFromMe View Post
    Agree. Your going to get oil all over the place. No worth it IMO.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Nov 19 2008
    S4 Twiny Terbs
    San Diego
    Im going 2 try the plyers.
    if not. This filter is going to die with my hands
    Feb 08 2007
    Pittsburgh
    Like this:
    -Jake
    [email protected]
    new siggy
    Nov 18 2008
    Chicago
    Tip: Next time make sure you lube up the rubber ring with oil and its on hand tight.
    Go BIG or GO HOME!
    Jan 29 2007
    08 S4 00 S4
    MD
    Buy a filter wrench first before you stab it. Do that as a last resort. I broke a wrench on a filter once and had to stab it and it wasn't pretty..
    08 S4- Stock SOLD
    Senior Member Three Rings 02alltoad's Avatar
    May 27 2008
    04 S4,Allroad,00 911,00 a6 4.2
    Arvada, Colorado
    and make sure the oil cooler does not start to spin if it dose use another pair of plyers and hold it, if it spins it could cause the seal thats behind it to leak. just my 2 cents
    Nov 19 2008
    S4 Twiny Terbs
    San Diego
    thank you guys for all the help mission accomplished
    after an hour of frustration it came off.
    decided to go with the filter wrench only because i had stabbed it and it looked like a bloody horror movie.
    p.s. IMO the S4 splash guard has by far the worst design of screws.(the ones right next to tires)
    Aug 06 2008
    Canadia
    wow, you guys are cave men when it comes to working on cars. but after that story of the guy cutting his control arms with a sawzall i'm not surprised.
    So, your problem is caused by a filter that wasn't lubed, or lubed with used engine oil instead of new, and most likeley tightened on way tighter than finger tight when it was first installed.
    the screwdriver method i would never use, if for whatever reason you can't get the filter off and you jab a screwdriver through it your car is completely useless until you find another method or buy the tools necessary to take it off. besides, the filter is made out of pretty thin metal and its possible to just bake a big gash in the filter and not actually remove it (not to mention make a big mess)
    first method is pretty neat, get a hose clamp and put it on the filter as tight as you can (closest to the base as possible, its the strongest area and least likeley to crimp) the screw part of the clamp would be accessable so you can position a flat head screwdriver on it and give the screwdriver a good whack and loosen off the filter.
    second method, the metal band oil filter wrench, these things are the best, for really stubborn filters, use two and have your buddy help. this method has never failed for me.
    last method i've never really used is the metal band filter wrench that uses a 3/8 extension, you could use one of those and a breaker bar, should work but i've never tried it.
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Aslo you can get a pair of oil filter pliers from napa and they are slip jaw and make oil filters change an easy deal,
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Registered Member Two Rings
    Jun 04 2008
    MA
    Quote Originally Posted by S4_NE View Post
    Similar to what I'm using.. Its a oil filter vise-grip from harbor freight, works like a charm. Had to use it for the first oil change on the S because of the PO had tightened it down too much. Like others had said you should rub clean oil on the rubber gasket before installing it and hand tighten it. Makes the next oil change easier.
    This same tool I mention helped me get the big screw on cap off for the fuel pump to access my fuel sender. Nice little tool and was cheap!
    Jan 17 2005
    2001 S4 - 2018 Subaru Legacy
    New Jersey
    Be carefull when stabbing it. The oil cooler is what the filter attaches to. You don't want to bust that. I had mine leak into the coolant. $650 job to get it fixed.
    Veteran Member Three Rings jeproks's Avatar
    Jul 14 2004
    Bahay Kubo
    Get this wrench at Sears before you do your next oil change.
    Feb 17 2008
    2001.5 s4
    yea dont jab i done that and ripped most of it lols
    end up having to use hose clamps clamping a lever to undo itt
    this was at likeee 12am and i had work the next day
    bought an oil filter wrench after that
    Established Member Two Rings AWD Mike's Avatar
    Oct 19 2008
    '14 Tacoma TRD Sport | '14 SQ5 Prestige
    Richmond, VA
    I had to annihilate my oil filter last week. None of the usual filter wrenches would loosen it. Just took a pipe wrench to it and broke half of it off, stabbed the rest with a screwdriver, and wah lah...
    That was the Audi's first oil change. There must have been no oil on the filter when it was first put on.
    And by the way, Macdaddy -- I always use the old engine oil to lube the oil filter, and not once had a problem. Care to shed some light as to why old oil should not be used? (Not trying to be sarcastic, really asking the question)
    -Mike
    Veteran Member Three Rings AWD87's Avatar
    Nov 23 2007
    01 S4
    Midwest
    just get a filter wrench from walmart, seriously. It's only about 5 bucks anyways
    Mar 14 2011
    Melbourne, Australia
    Quote Originally Posted by A4 Meets 27t View Post
    Hand tight ?? I did it once and then when i started the car almost half of the oil gushed out of OIL Filter seal, I had to refill the oil and then tighten the filter with wrench.
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    I stabbed it once on my old ass honda... Will never do it again.
    I basically shredded the outer cannister, but the dang base was still on TIGHT.
    Took me 1.5hrs just to get the base off.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Veteran Member Four Rings KNaudi's Avatar
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    jesus guys, just get a filter wrench for $4 that fits the filter you use. I don't even struggle to get mine off.
    My WTB List:
    -Sport (all black) shift surround for 6MT
    -Sport (all black) ash tray cover
    KNaudi's story
    Dec 05 2007
    Quote Originally Posted by curlyfrieS4 View Post
    Use a nickel. Saves the trouble of having to manuveur around the tire for a flat head screw driver.
    Jun 14 2007
    2000 S4
    Connecticut
    The filter wrenches will usually work on the OEM filters as mentioned above. There was a time period when I would buy the PureONE Purolator (I don't anymore for this reason) and the damn thing started crushing from the pressure of me trying to turn the wrench. Then I went from the smooth wrench one you're used to seeing to a claw type one which made it worse. Took a long flathead and a hammer and went through the sides, turning the handle and repeating.
    Now I only use MANN filters and I haven't seen this problem. The PureONE was fine but it was way overtightened. I only handtight as much as I can then give it a 1/2 turn with the wrench.
    Veteran Member Three Rings alm001's Avatar
    Dec 29 2010
    I wonder how many oil changes the OP has been through in the last 2 years.
    -Andrew
    Jul 28 2008
    01.5 S4, 09 Touareg, 88 Cabriolet 16vT
    Pittsburgh PA
    i think the screws are a decent design... just have a stubby screwdriver set or turn the wheel? :dunno: and LOL @ stabbing the oil filter... realistically the S4 has a great location for a stuck oil filter... easy to get leverage on it and whatnot...
    Veteran Member Four Rings BlkdoutS4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    This just happened to me when I tried to remove my Bosch filter. Thing crumbled like a soda can. Put on the replacement Mann filter and it seems like much nicer quality.
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    What? You tighten as much as possible with your hands and than give it an additional 1/2 a turn with a filter wrench????
    And people wonder why filters don't come off. There is absolutely no need for that. Hand tighten the filter and leave it be. It will not come off on it's own.
    Jun 14 2007
    2000 S4
    Connecticut
    Lol it's like a last security measure. I tighten the hell out of it by hand so I'm probably OK as is. I meant to type 1/4 turn too, I honestly just am flipping between internet, and work.
    Dec 05 2009
    New York
    Quote Originally Posted by jeproks View Post
    this thing is the man!
    Veteran Member Three Rings tosh2.7's Avatar
    Sep 12 2009
    Nogaro stg 3- 00' S4(dead but being rebuilt), Silver stg 3 00 S4 GF 2010 civic
    new york
    is this really happening
    Vast tested. Driver approved
    BUY my BBS REs
    tosh2_7 on instagram: Get at me
    -RAY-
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    fwiw k&n hp-3001 is what I use.
    1" nut on the end in case it decides to be too tight.
    the first oilchange I ended up having to chisel the base around (after impaling the filter and tearing it apart) until it was loose enough to come off. PO gorilla'ed the filter on.
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    Aug 08 2007
    San Francisco, CA
    The best I came across is Channel Lock's Oil Filter Pliers. Good grip and torque.
